Smoothing of Keyframe curves?
COW Forums : Apple Motion
Jim Waterwash
on Apr 27, 2012 at 9:30:21 pm
I am manually trying to match 2 video clips frame by frame and the result of my changes to the transform, still results in some jerky movements. Is there any way to smooth out the resulting keyframe curves?
Jim
Stephen Smith
Re: Smoothing of Keyframe curves?
on Apr 27, 2012 at 9:38:32 pm
Click on the Keyframe editor button or hit Command and 8. There you can select keyframes and set them to Bezier which will give the moves a smooth look.
Stephen Smith
Utah Video Productions
Check out my Vimeo page
Jim Waterwash
on Apr 28, 2012 at 1:52:41 am
Thanks, I guess I was hoping for something that used a bit more intelligence and would round the points on the curve, so if one keyframe was too off, the keyframe values themselves would be altered. I saw there was an "average" function within the keyframe editor, so I guess I need to look further into it.
Stephen Smith
on Apr 30, 2012 at 1:41:00 pm
A Bezier curve is rounded. It will ease your animation in and out. Sounds like something is wrong. You may also want to check out continuous.
Stephen Smith
