Motion 5 generator render qualityin in fcpx
COW Forums : Apple Motion
Imari Childress
on Apr 11, 2012 at 9:20:02 pm
Posted this question in January and got no reply. Nobody can answer this??
When I create a generator/effect etc to use in fcpx, how do I know that the generator is rendering at the highest quality when i play in fcpx? Does that depend on the settings when I save the motion generator?
For instance, if I'm working in motion at a lower resolution and render quality, will that carry over to fcpx?
How do I make sure that motion generators are rendering at their highest quality in fcpx?
Simon Ubsdell
Re: Motion 5 generator render qualityin in fcpx
on Apr 13, 2012 at 3:30:46 pm
When you use a Motion template inside FCPX you will always get the highest possible resolution regardless of how your Motion project is set up.
Simon Ubsdell
http://www.tokyo-uk.com
Jarek Komárek
on Mar 8, 2013 at 7:52:52 pm
I actually don't get the best quality. When rendered right from Motion, the quality is apparently better. I didn't find any mention of quality control in the manual. I'd even expect quality parameters such as motion blur on/off switch available for publishing. Is this possible?
Mark Spencer
on Mar 11, 2013 at 2:06:30 pm
No, you can't publish motion blur parameters.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Jarek Komárek
on Mar 12, 2013 at 5:07:51 pm
Too bad. Motion Blur can solve unpleasant flickering. Maybe in next version? :)
