Glacial Motion 4 - for just THIS project?! tried most everything
COW Forums : Apple Motion
stu aull
on Apr 2, 2012 at 9:34:45 pm
Cheers folks:
getting 1fps preview/playback in Motion 4 on just this one project.
Played back MUCH better earlier (like: 20fps+, last week) when original constructed.
Mac Pro latest,
12Core - 16GB RAM
OS 6.8
√Usual 1st step of delete the pList in Prefs -
√numerous re-boots of computer betw these ops
√copied/renamed file
√turned OFF all the fancy "Shadow/depth of field/motion blur" playback functions
√even set to DRAFT (which I did NOT have to do originally)
√even set to 1/4 resolution playback (which I did NOT have to do originally)
√cleared RAM preview
Opened other projects and they perform fine.
stumped!
thanks in advance
Stu Aull
Alaska
Stephen Smith
Re: Glacial Motion 4 - for just THIS project?! tried most everything
on Apr 2, 2012 at 9:37:48 pm
How long is this video? Does it use the replicator or particles a lot? Does it have a lot of layers?
Stephen Smith
Utah Video Productions
Check out my Vimeo page
stu aull
on Apr 2, 2012 at 9:49:10 pm
Hi Stephen! (love your tutorial stuff)
Its fairly complex (but jeez, its motion so aren't most??)
5- camera layers (1 after the other)
11 drop zones (floating pictures)
3 background "walls" -images
1-power-sucking light flare, which I disabled and actually layered in a second pass, so presume "turning it off" should speed things up (certainly did for the render!!)
Again - this whole project was speedy enough last week to allow me to run to at least judge ease-in/outs etc in playback but NOW at 1fps?? no way :(
cheers
Stu
stu aull
on Apr 2, 2012 at 9:43:39 pm
OK-
should add
-30fps/30sec/900frame
1080iHD project
I loaded the "naked" version of this file (it is a purchased template), and without all the DropBox images (ie mine, all under 1MB), it plays at 9fps. Still glacial.
I do a LOT of SD in motion, so maybe I expect too much from HD? But, Jeez!: 12Core/16GB Ram? I mean...
really??
Stu Aull
Alaska
