Illustrator Files in Apple Motion 5
COW Forums : Apple Motion
Thomas Frank
on Mar 29, 2012 at 11:14:51 am
Hi is there away to import Illustrator files in Apple Motion 5 so it does not turn into a bitmap?
I have map that was created in Illustrator and when imported in Apple Motion 5 it turns itself in a bitmap.
Simon Ubsdell
Re: Illustrator Files in Apple Motion 5
on Mar 29, 2012 at 11:57:02 am
Go to the Media tab for your imported Illustrator image and make sure you deselect Fixed Resolution. That way you can scale all you want and you'll keep the nice clean vector image.
Simon Ubsdell
http://www.tokyo-uk.com
Thomas Frank
on Mar 29, 2012 at 12:35:47 pm
Thanks that did it!
To bad you don't have all the same function like a vector that was created in Motion :(
