Trimming an object in Motion 5
COW Forums : Apple Motion
Phil Munckton
on Mar 15, 2012 at 7:30:21 am
I might have missed something here in 5 but in Motion 4, to trim the IN or OUT point of an object to the cursor position you would hit I or O
Although the manual for 5 says the same works, pressing I or O moves the PROJECT START point to that location not trimming the object.
Holding shift and pressing I take the cursor to the start point. Have they done away with the one key stroke Trim or is it hidden somewhere else, cause I cant find it
Thanks Phil
Mark Spencer
Re: Trimming an object in Motion 5
on Mar 15, 2012 at 2:40:23 pm
I and O work the same in Motion 5. Try trashing your prefs.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Phil Munckton
on Mar 16, 2012 at 3:25:11 am
I tried That Mark No result
Strangely enough in the drop down menu bar in motion 4 there is an I and O indicating keyboard short cut to Mark in and Mark out.
Yet in Motion 5 Its not there.
I have 5.0.2 is there a bug fix in a later version?
Mark Spencer
on Mar 16, 2012 at 3:57:02 am
5.0.2 is the latest. Just trash the app and redownload from the App store.
Mark Spencer
Phil Munckton
on Mar 20, 2012 at 6:10:08 am
mark Just downloaded Motion again and the same thing still exists.
Mark play range in is the 'I" and mark play rang out is the "O"
The is no I & O on mark in and out as it in in Motion 4. What version of Motion are you using to have it work the same as 4?
Thanks Phil
Mark Spencer
on Mar 20, 2012 at 12:40:58 pm
5.0.2
Mark Spencer
Phil Munckton
on Mar 21, 2012 at 12:28:57 am
I see your is working correct but a screen shot of mine is attached. could it be a keyboard setting or something
Phil Munckton
on Mar 21, 2012 at 12:51:30 am
Found the problem
Under Motion in the menu I selected commands and found it was set to Final cut Pro set changing it to standard set brought up the normal settings as it should be
Mark Spencer
on Mar 21, 2012 at 1:05:44 am
I should have known - that same issue tripped me up in FCP X!!! Glad you figured it out.
Mark Spencer
