Illustrator to Motion with edit point enabled
COW Forums : Apple Motion
João Cunha
on Mar 2, 2012 at 12:47:00 pm
Hi.
I just created a toon in illustrator and used meshes to color it. Now I'd like to import it to motion to animate it. How can I make the export/import so that I keep my mesh point editable in motion?
Thank you.
Mark Spencer
Re: Illustrator to Motion with edit point enabled
on Mar 2, 2012 at 2:20:49 pm
There's a great script that will turn any simple paths in Illustrator into Shapes in Motion, complete with control points:
http://www.motionsmarts.com/downloads.html
Here's a short movie on how to use it:
http://pixelcorps.cachefly.net/mbks_061_540p_h264.mov
However, it only works on simple paths, one at a time, so it may not work for what you are trying to do.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
João Cunha
on Mar 2, 2012 at 2:31:59 pm
I've already tried that script but it asks me to select shapes when I select my mesh. I don't think I'll be able to make it work.
Do I need to start the toon over again? There is not a chance I can control the main points of the shape to deform it a bit and animate them in motion?
Thank you Mark.
Mark Spencer
on Mar 2, 2012 at 3:38:02 pm
Like I said, it only works with simple shapes. Sounds like you need to use the Puppet Tool in After Effects to do what you want.
Mark Spencer
