Black Lower Thirds & down stream keying
COW Forums : Apple Motion
Greg Davis
on Feb 24, 2012 at 4:30:32 pm
I have created a lower third in motion five that contains black. When I Broadcast thru DSK on my switcher all of the black is keyed out and transparent. Does any have a solution for this problem.
Mark Spencer
Re: Black Lower Thirds & down stream keying
on Feb 24, 2012 at 4:55:42 pm
Edit > Project Properties. Change the Background from Transparent to Solid.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Greg Davis
on Feb 24, 2012 at 6:20:35 pm
Changing that did help, some of the black did come back, but some of the black is keying out. I am exporting from motion 5 and running the QT video thru (On the Air Video) and into my switcher (Panisonic HS400). It my be a setting in my switcher. When I create graphics in On the Air CG. It also keys out everthing black. Please let me know any suggestions you have.
Mark Spencer
on Feb 24, 2012 at 6:37:47 pm
Are you exporting in a format that supports an alpha channel, like Animation or ProRes 4444? And does your switcher support the codec you are using?
Mark Spencer
