Can an added layer conform to group duration automatically?
COW Forums : Apple Motion
Tangier Clarke
on Feb 4, 2012 at 8:36:55 pm
I want to add my media to layer groups in a way that when I add to any media to the group, the duration of the added media conforms to the duration of the group. Right now I have to always position the media (or filter/ behavior for that matter) and set the in and out to match the group I put it in. I'd like to avoid these mundane steps.
Tangier
Mark Spencer
Re: Can an added layer conform to group duration automatically?
on Feb 4, 2012 at 8:41:32 pm
Media should start at the playhead position, unless you've changed that default behavior in preferences - so you can select your group and press Shift-I to quickly move the playhead to the group's In point, then add your media. You'll then need to select the group again, press shift-O to move to the end of the group, select the new media, press O to trim it to the playhead. I don't know of a faster way.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Tangier Clarke
on Feb 4, 2012 at 9:00:41 pm
Thanks Mark. That's what I'm used to doing, except for the occasional time I don't have the playhead at the group in point. It was a long shot, I was just wondering if there was some sort of "snap-to-group" key combo or something. Wishful tinkling I guess.
Tangier
