Can you export with hidden layers visible in final product?
COW Forums : Apple Motion
Mike Soprano
on Jan 5, 2012 at 6:04:11 am
I have a large project that I need to export as one continuos piece. The only problem I have is that I cannot make all the groups visible at the same time because Motion can not handle them and crashes. Everything is the way I want it, is their a way I can export the project where the layers I have hidden still appear in the final export?
Thanks in advance.
Mark Spencer
Re: Can you export with hidden layers visible in final product?
on Jan 5, 2012 at 2:10:22 pm
Why don't you "bake" certain complex groups by exporting just that group, and replacing the group with the baked movie? Motion can do this for you semi-automically using Export Selection and there's an option to reimport into project in the export dialog. Once you've done this a few times, you should be able to then export the full project.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Mike Soprano
on Jan 5, 2012 at 4:00:43 pm
Well obviously! Thanks Mark, that helped a lot. I really enjoy your tutorial/tip videos on applemotion.net, keep up the great wok.
