Time Lapse in Motion 5
COW Forums : Apple Motion
James Taylor
on Nov 28, 2011 at 7:58:30 am
Can anyone point me to the best way to do this? I'd like to do some time lapse movies from images with my 5DMKII. I'd like to assemble the time lapse in Motion and then finish it in FCPX.
JT
JT
Mark Spencer
Re: Time Lapse in Motion 5
on Nov 28, 2011 at 2:02:05 pm
I would assemble your timelapse images in Quicktime 7 by importing the image sequence and then exporting a ProRes movie, which you can then bring directly into FCP. Not sure why you would need Motion.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
James Taylor
on Nov 28, 2011 at 2:13:26 pm
I don't own QuickTime 7. Was hoping to do this without buying anything else. QuickTime 7 doesn't come with FCPX or Motion 5 - does it?
JT
Mark Spencer
on Nov 28, 2011 at 2:20:05 pm
It comes with your Mac. You could probably use QT X as well, I just prefer QT 7 as it has more features.
Mark Spencer
James Taylor
on Nov 29, 2011 at 1:55:34 am
Thanks for your time Mark - appreciate it!
My Mac (early 2011 15" macbook pro) came with Quicktime 7, but not the pro version. Looks like it takes the pro version to import image sequences. Too bad it didn't come with FCPX or Motion 5. Also, it looks like Quicktime X can't import image sequences (at least that I can see).
So, I guess I could purchase Quicktime 7 Pro for 30.00. However, it seems like I should be able to do this in Motion.
1) I batched corrected all my images in Lightroom and exported the images at a manageable size.
2) I imported the image sequence into Motion 5 - set project to 24P.
3) Everything played fine, but it was faster then I wanted.
4) I exported as a prorez file and then took it into FCPX.
5) I added music and slowed the footage down to 25%.
6) Exported the movie and everything was fine.
The process was fine, but I'm wondering how much I'm degrading the movie by slowing down 25% in FCPX? Is there a simple way I can tell Motion 5 the length I want each image to be? That way the file coming out of Motion 5 would be perfect. Or, can anyone suggest a better way without Quicktime 7 Pro?
Thanks again,
JT
JT
Mark Spencer
on Nov 29, 2011 at 5:09:56 pm
You get Quicktime Pro with FCP X.
But your workflow is just fine. You can slow the image sequence down directly in Motion in the Timing section of the Properties Inspector. If you slow it way down, you could try Optical Flow frame blending as well.
Mark Spencer
James Taylor
on Nov 30, 2011 at 4:17:18 am
Thanks Mark!
JT
JT
