Odd render issue in FCP using Motion Project?
COW Forums : Apple Motion
Thomas Morter-Laing
on Nov 22, 2011 at 10:04:05 pm
OK so firstly I'd rather have an actual motion project rather than an export on the timeline because I have quite a few animations and I'd like to be able to dip in and out of them.
The FCP project settings are:
This hasn't been a problem so far but for some reason is in this instance. Im working with an adobe illustrator file (vector) and its a REALLY simple animation- its a small logo in the top right (the illustrator vector file). There is a duplicate of the logo one on top of the other, one with a glow filter (from fxfactory) and one without. I use a mask to make it as if the glow goes down the image- simple stuff. The top logo has reduced opacity. I don't know how any of that would cause this issue but the more info the better.
Anyway, here's the weird bit- in FCP, when the motion project is on the timeline, its looks fine, except it needs rendering (orange because RT is set to unltd). It even plays back OK like that, keeping its looks (just losing a few frames perhaps). Underneath it on the FCP timeline there is a white solid. (removing it makes no difference)/ When I go to actually render it, the motn clip looks fine when its not playing, but when its playing back it goes REALLY fuzzy. When I try and export it, it looks kind of OK, but it should be flawless and totally clear! (Its a vector image!!!)
Ive used all the same settings in other animations in the same way and it looks fine with them. Any ideas?
Oh the motion prom settings are:
For now I CAN just export the thing ad its OK, but would rather not have to because this is a client who likes changes, and Id rather not having to keep re-exporting stuff. Also for the record Ive tried playing with the project settings in Motion to little avail- changed it to Broadcast HD, changes the pixels to square and all sorts. Im baffled :S
:D
Stephen Smith
Re: Odd render issue in FCP using Motion Project?
on Nov 22, 2011 at 10:13:21 pm
Take a look at this post and see if it is of help: http://forums.creativecow.net/thread/170/860863#860865
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Thomas Morter-Laing
on Nov 22, 2011 at 10:49:42 pm
Im grateful for the response, but that didn't help at all- that post seems to be in regard to orange flash frames, but if you read mine you'll see that's not the issues...
Tom Morter-Laing
Editor
Certified Apple Product Proffessional, 2010
Thanks if you can help :D
Equipment (not for 'bragging', but in case it's relevant to future posts :D): Canon 7D, with Rode NTG2.
iMac 27" intel i7 3.4GHz, 12GB RAM, ATI HD 6970M [2GB GDDR5], G-Tech G-RAID 2TB (soon to be over eSata!). Elgato Turbo H264HD.
