Blend Mode Effect over one Layer?
COW Forums : Apple Motion
Thomas Frank
on Nov 8, 2011 at 2:39:21 pm
Hi is there a possible way to have layers Blend Mode only effect the layer underneath it?
So it does not show up over the other layers in the chain underneath it's layer.
Mark Spencer
Re: Blend Mode Effect over one Layer?
on Nov 8, 2011 at 3:06:40 pm
Sure. Put the two layers in a group, and set the group's blend mode to Normal.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Thomas Frank
on Nov 8, 2011 at 3:39:46 pm
Yeah I tried that but it seems not to work.
I want create a highlight for a text graphic but when I set the group to normal the highlight (line object in white) doesn't turn transparent out side of the graphic.
Mark Spencer
on Nov 8, 2011 at 4:40:12 pm
The Stencil Alpha blend mode will restrict the layer it's applied to based on the alpha channel of the layer underneath.
Mark Spencer
