Why are my straight edges appearing jagged?
COW Forums : Apple Motion
Peter Gordon
on Nov 4, 2011 at 1:47:43 pm
HI I have just finished a project - an info graphic with objects I have mostly drawn in motion. All the edges were crisp and clean. And I have just noticed in the last half hour of finishing that it has all straight lines appearing slightly jagged as though something has been altered slightly. It has affected every scene in the project. Please help!
Stephen Smith
Re: Why are my straight edges appearing jagged?
on Nov 4, 2011 at 1:51:44 pm
Set your project to best on export. If you are placing the project file in FCP go up to Sequence, Settings. Click on the Render Control tab and check the "Always Use Best Quality When Rendering Movies" check box and that will to the trick. Best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Peter Gordon
on Nov 4, 2011 at 2:29:51 pm
Please Ignore - problem solved.
