Moving from Motion 3 to 5
COW Forums : Apple Motion
Marc Lucas
on Oct 30, 2011 at 9:49:35 pm
Got FCS2 on both my home and work Macs. I have Motion 5 installed on a separate drive but want to make the transition to Motion 5 on all machines. What are the caveats with the move...
1. Do I uninstall Motion 3 and just replace with Motion 5?
2. Can Motion 5 open Motion 3 projects (which is my biggest worry because I have a ton of Motion 3 projects that I need to access)
Mark Spencer
Re: Moving from Motion 3 to 5
on Oct 31, 2011 at 1:59:38 pm
You don't need to uninstall Motion 3 in order to install Motion 5.
You should be able to open your Motion 3 projects in Motion 5 - but you can't go the other way.
You can't import Motion 5 projects into FCP7, nor can you roundtrip from FCP7 to Motion 5.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Marc Lucas
on Oct 31, 2011 at 2:36:35 pm
Thanks mark
Just was concerned that the two apps (Motion 3 & 5) would work ok on the same system really. I knew about the round tripping thats not a problem right now. I'm just slowly transitioning from FCS2 to FCP X Motion 5 and I have a ton of old projects that I need to access so being cautious and making sure my system(s) keep running normally.
