 | Pictures with movement in 3D space break up as they move
on Oct 26, 2011 at 4:14:53 pm |
I am relatively new to Motion, so I'm guessing this could be a pretty simple answer. I created a fairly simple Motion project that contains 4 pictures moving along a motion path within 3D space. The motion path is a closed circle that allows the pictures to move toward the camera and then away. They are moving at a steady rate of speed. When I bring the Motion project into FCP, I notice that the pictures are breaking up a little bit. I appears like there are scan lines that move down the picture. I tried De-Interlacing the Motion project after I brought it into FCP, but that didn't help much. Are there any settings I am missing? Any other filters I should try using?
 | Re: Pictures with movement in 3D space break up as they move on Oct 27, 2011 at 11:23:24 pm |
Did you export out the video or did you just place the Motion project into the FCP timeline?
Stephen Smith
Utah Video Productions
Check out my
Motion Training DVD
Check out my
Motion Tutorials
