Motion 4 Keyboard shortcuts problem
COW Forums : Apple Motion
David Eells
on Oct 14, 2011 at 7:40:57 pm
On my home setup, Motion 4 does not respond to keyboard commands unless the canvas is highlighted. SInce I use the keyboard a lot, it's driving me crazy that I can't make an adjustment in the timeline and hit the spacebar to play - I have to make the canvas active first. Or better yet, extend a layer in the timeline by hitting"o". This doesn't happen at work, so I know it's not universal.
Can anyone point me to the hidden control that will make keyboard shortcuts active ALL the time?
Andy Neil
Re: Motion 4 Keyboard shortcuts problem
on Oct 20, 2011 at 3:41:30 pm
Unfortunately, there's no hidden control like that and Motion shortcuts are sometimes dependent upon which section of the app (utility, viewer, or timeline windows) is active.
However, CMD+` (tilde key) is the shortcut to toggle between the open windows so if a shortcut isn't working, you can usually just toggle to the viewer window so it will.
Andy
http://www.timesavertutorials.com
