Reverse /invert star field particle emitter
COW Forums : Apple Motion
Joe Coyle
on Oct 9, 2011 at 11:55:49 pm
Hi
I am new to motion so please be patient with me :). I have added the star field particle emitter to the canvas, and can see the stars are flying towards me. How can I reverse the effect so that the stars fly away from me in the opposite direction?
Joe
Don Eitner
Re: Reverse /invert star field particle emitter
on Oct 16, 2011 at 10:57:43 pm
Is this for use within Motion itself or as a clip in Final Cut? If the star field will be used as a clip within Final Cut, you could just render it out from Motion as a movie and then in Final Cut go into the Speed setting for the clip and set it to reverse.
Sean Daniel
on Aug 4, 2012 at 3:24:10 am
To reverse an emitter in apple motion
1. select the emitters group
2.Go to the object menu and select make clone layer
3.turn off the original layer and select the clone layer
4. go to the properties menu in the inspector and under timing you will now find an option for reverse
5. select reverse
all done!
