match motion corner pinning a mask
COW Forums : Apple Motion
Ed Caraballo
on Oct 6, 2011 at 9:34:09 pm
I am trying to blur some bad reflection in a rectangular area on a moving shot in MOTION 5. According to the user guide, I'm supposed to choose behavior "analyse motion," align the first tracker to the upper left of the rectangle, add 3 trackers, going in a clockwise motion around the rectangle, apply that motion tracking data to the mask. then I'm supposed to choose "4 corners" from the type of match move. the problem is that when I select the mask, in the blurred copy of the clip that I want to mask... and select "match move" the mask type is greyed out and I cannot select "4 corners" any ideas about why?
Thanks Great Cow!
Ed
Stephen Smith
Re: match motion corner pinning a mask
on Oct 7, 2011 at 3:15:53 pm
Duplicate the clip so you have it in your timeline twice. Use the Bezier tool on the top clip and create for points that are on the four corners you want. Add the Track Points behavior to the mask. Click Analyze and the mask points will track what you want. Add the blur tool and you are good to go. Best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Ed Caraballo
on Oct 7, 2011 at 4:20:33 pm
Got it....that makes sense! awesome. thanks SO much for responding, Stephen.
Stephen Smith
on Oct 7, 2011 at 4:21:21 pm
Happy to help. Best of luck.
Stephen Smith
