Alpha channels and write-on text
COW Forums : Apple Motion
Rich Franklin
on Oct 4, 2011 at 12:12:24 pm
I have a write-on behaviour on a shape (with Image Mask applied) that reveals some text underneath that is actually a TIFF file with transparency. I want to know if I could actually use the ALPHA channel within the TIFF file to convert to either the shape that draws the text, or as the image mas. This will then give me an accurate outline of the script font.
My other issue is that I want the shadow to draw at the same time. The normal shadow is switched on but it is not visible in the animation. With Drop Shadow turned on, the rough outline of the shape reveals it but it is the shadow from the text, not the shadow from the light in the scene.
Thanks.
Jeff Greenberg
Re: Alpha channels and write-on text
on Oct 5, 2011 at 11:57:40 am
Write on - use an Image Mask - the shape that draws the text goes in there.
The shadow? you may have to build it as a separate element with the identical image mask, or build a 3d lighting system.
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
New- my book (with Richard Harrington and Robbie Carman)- An Editor's Guide to Adobe Premiere Pro
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
