Motion 5 fullscreen problem
COW Forums : Apple Motion
Jonathan Geange
on Sep 7, 2011 at 5:43:35 am
Can anyone tell me how to get Motion 5 to go fullscreen using the F8 key?
It says in the settings that F8 is assigned to fullscreen but when I press it does nothing and makes that sound where you've pressed an unassigned key?
This works fine in Motion 4, is this a fix that needs addressing?
Mark Spencer
Re: Motion 5 fullscreen problem
on Sep 7, 2011 at 1:16:42 pm
I assume you are on a laptop, which means you need to hold down the fn key before pressing F8 - unless you go into System Prefs, keyboard, and check the "Use F1, F2, etc..." checkbox
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Jonathan Geange
on Sep 7, 2011 at 10:27:28 pm
Thanks for your effort Mark, unfortunately I have tried your suggestions and I still don't know why this is not working?
The option is greyed out for some reason, and I only have one project open.
Not really impressed with Motion 5 so far and it's looking like I will need to revert back to 4 :/
Mark Spencer
on Sep 7, 2011 at 10:36:32 pm
It's not possible to have more than one project open with Motion 5. Are you sure you are using Motion 5? F8 should say "Player Mode"
Mark Spencer
Jonathan Geange
on Sep 7, 2011 at 10:54:05 pm
Wow that is strange? Yep it sure is Motion 5...this is so bizarre!
I am running it on a MBP with Lion installed and everything is upnto date.
Wierd!
Mark Spencer
on Sep 7, 2011 at 11:07:41 pm
Ah, you are on Lion - that is the problem.
Mark Spencer
Jonathan Geange
on Sep 7, 2011 at 11:20:06 pm
No way!
So I can't get full screen preview with Lion?
Mark Spencer
on Sep 7, 2011 at 11:42:26 pm
I believe it's a bug - we discovered it during our training week before last. Another bug with Lion: in FCPX, if you apply a title, you can't change its location in the Viewer.
Mark Spencer
Jonathan Geange
on Sep 7, 2011 at 11:54:56 pm
Thanks Mark, I thought I was going crazy!!!
I really hope they sort that bug out ASAP, I have no choice but to re-install Motion 4 now :/
Pretty much wasted $50 so far...it's very slow on my computer compared to M4, mainly due to it being only 16 or 32 bit only.
Sometimes software updates can be more of a down grade :(
Mark Spencer
on Sep 8, 2011 at 12:16:29 am
Not being able to do full screen preview is forcing you back to M4?? Why?
Mark Spencer
Jonathan Geange
on Sep 8, 2011 at 12:29:48 am
I've devised a system that captures the fullscreen animation using another screen capture program and it is completely ruined if I can't get the full screen view.
I will use Motion 5 for other projects.
Thanks again for your assistance :)
Jonathan Geange
on Sep 8, 2011 at 6:56:48 am
A couple of last questions...does this bug affect Motion 4 on Lion?
Would it be best to install Motion 4 on a separate partition running Snow Leopard?
Or could I just install Motion 4 on the same Lion partition where Motion 5 exists?
Mark Spencer
on Sep 8, 2011 at 1:10:29 pm
Haven't run M4 on LIon so don't know. Separate partition is safest - but I run M4 and M5 (and FCP7/FCPX) on the same partition on Snow Leopard - with the caveat of following Apple's advice:
http://support.apple.com/kb/HT4722
Mark Spencer
Andrew Tan
on Oct 11, 2011 at 7:10:15 am
Hey this might be late but still, hope I can help:
I was having the same problem as yours, but it was solved when I updated Motion to 5.0.1, I didn't even see the "Playmode" back in Motion 5.0, maybe it's a new feature??
Anyway, I'm also running motion on Lion, I think all you need to do is to update Motion.
Cheers
Andy
How soon is now?
Brady Wurtz
on Apr 12, 2012 at 5:36:55 am
how does full screen work for you? i'm not sure how you got it to work but are you sure you're on lion and using Motion 5?
I have Motion 5 installed on Lion 10.7.3 and there is still no full screen option.
I've been on the latest update of Lion for each installment of Motion 5, i got the program 3 weeks after it came out.
Every time there is an update in the program I download it right away, in hopes that they'll finally add full screen to it but they never do.
could you please provide a screenshot of you using Motion 5 with Lion and show where you can choose to go full screen?
Jonathan Geange
on May 29, 2012 at 12:31:28 am
Sorry mate...doesn't work :(
I don't think the other guys understand what we mean when we say we want "fullscreen". I don't want borders and any play bars underneath the screen area!
Have to revert back to M4 for this feature obviously :/
