Video wall, different content in each screen?
COW Forums : Apple Motion
Christopher Travis
on Sep 5, 2011 at 11:06:45 am
Hello,
I'm sure this is an easy one but I can't figure the best way to do it.
So I need to make a wall of about 25 screens, each with a different persons head in it. I have put one clip into the project, then used the replicator to make a 5x5 box. Now is there a quick way to fill the screens with different people?
Chris
Christopher Travis
Re: Video wall, different content in each screen?
on Sep 5, 2011 at 12:47:25 pm
After looking around, the best idea I have come up with is to make a long video clip in FCP, featuring all of the people, one after the other, on screen for a set number of seconds, then import that into the replicator, and then change the frame start offset so that each box shows a different person.
Is there an easier way than that?
Mark Spencer
on Sep 5, 2011 at 2:35:09 pm
That's what you need to do if the shots need to be video. If the headshots can be stills, then use an image sequence.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Christopher Travis
on Sep 6, 2011 at 9:30:00 am
Thanks Mark,
I ended up using this method to get it done.
