Motion 5 in a Final Cut Pro 6/Motion 3 Environment?
COW Forums : Apple Motion
Graden Hudson
on Aug 25, 2011 at 2:49:36 pm
I've Googled the hell out of this, and couldn't find an answer. So I'm hoping someone here can...
I would like to use Motion 5 on two workstations that currently have Final Cut Pro 6 and Motion 3. I understand that round-tripping won't work between Motion 5 and Final Cut Pro 6, but would installing and using Motion 5 delete or modify my Motion 3/Final Cut Pro 6 apps?
And if I'm understanding correctly, I can just export Motion 5 projects as video files to use in Final Cut Pro 6, right?
Thanks for any help!
Mark Spencer
Re: Motion 5 in a Final Cut Pro 6/Motion 3 Environment?
on Aug 25, 2011 at 2:57:45 pm
I haven't test this with FCP6/Motion 3 but it *should* work the same as with FCP7/Motion 4: when you install FCP X/Motion 5, your existing apps get moved to their own Final Cut Studio folder in the Applications folder. I'm sure installing Motion 5 won't delete your old Motion 3.
You should read through this article however:
http://support.apple.com/kb/HT4722
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Graden Hudson
on Aug 25, 2011 at 3:16:55 pm
That's great info. Thanks so much! Do you know if I can open Motion 3 and Motion 4 projects in Motion 5?
Mark Spencer
on Aug 25, 2011 at 3:40:37 pm
You can open Motion 4 projects in Motion 5 - I haven't tested Motion 3 but I suspect it would work fine.
Mark Spencer
Graden Hudson
on Aug 25, 2011 at 4:09:01 pm
Good to know. Thanks!
