Adobe illustrator shapes to motion 5 shapes
COW Forums : Apple Motion
Javier Zarracina
on Aug 10, 2011 at 5:31:04 pm
Has anybody find a way to convert AI shapes or paths into motion's 5 shapes?
I know it was an script for an older version of Motion, but doesn't seem to be working with Motion 5
Mark Spencer
Re: Adobe illustrator shapes to motion 5 shapes
on Aug 11, 2011 at 12:48:51 am
I would just use the script in Motion 4, then bring the shape into Motion 5.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Javier Zarracina
on Aug 11, 2011 at 1:12:29 am
Thanks Mark. Unfortunately, i'm a new adopter, so i only have Motion 5.
When I open the .motn archive generated by the script i only get a blank file.
In any case i hope than someone create a new script or find an easy method to import shapes from AI
(I'm creating a write-on effect of lines "drawing" the image of a building and i'm finding it difficult to draw the shapes with the Motion vector tools)
Mark Spencer
on Aug 11, 2011 at 1:54:20 am
Javier, the script generates a shape object, not a Motion project file. Try importing it into Motion 5.
Mark Spencer
Javier Zarracina
on Aug 11, 2011 at 9:16:22 pm
hmmm. The script i'm using is:
http://www.motionsmarts.com/downloads.html
and it generates a .motn file.
When i try to import it as a shape in Motion 5, it dont let me open it.
(and if i open it as a motion project, is blank)
Anyway, thanks for your help Mark :)
Mark Spencer
on Aug 11, 2011 at 9:31:11 pm
Works perfectly for me, I just tested it. Shows up as a shape in the File Browser in Motion 5.
Mark Spencer
Javier Zarracina
on Aug 11, 2011 at 9:44:31 pm
Of course! the file browser (i'm a fool, i was expecting it to appear in the layers panel)
Thanks for your help Mark!
safeer mongam
Re: Adobe illustrator shapes to motion vector art
on Feb 22, 2012 at 9:03:55 am
hello Sir,
How to create illustrater path as a motion file like vector art,pls help me if u can
Mark Spencer
on Feb 22, 2012 at 2:00:03 pm
Motion can import a Illustrator file as .ai or .pdf, then you turn off fixed resolution in order to scale to any size you like with no loss of resolution.
http://pixelcorps.cachefly.net/mbks_008_540p_h264.mov
You can also turn any Illustrator path into a Motion shape object:
http://pixelcorps.cachefly.net/mbks_061_540p_h264.mov
Mark Spencer
Jim Nelson
on May 1, 2012 at 8:12:31 pm
Wow Mark! You did it again. Awesome tutorials. They really came in handy for me today! I'm animating a tree I drew in AI using Motion and was wondering how I'd go from one to the other. I used to use PS as an intermediate and had no idea I could uncheck the fixed res box on a PS file. I thought that was just for PDFs. Heck, now I don't have to thanks to the plugin. I learn so much with your tuts!
I still refer back to your Apple Pro Training book on Motion 4.
Thanks for all you do (free and for profit!).
Mark Spencer
on May 1, 2012 at 8:43:33 pm
Um - you can't just uncheck "fixed resolution" on a PSD file - that will only work with a vector file like a .ai or .pdf saved from Illustrator. How did I give the impression it would work on a Photoshop file?
Mark Spencer
Donald Anderson
on May 29, 2012 at 4:26:23 pm
I came to this thread via a google search. My question relates, so hope it's alright to add it here, rather than to a new thread. I have used the motionsmarts.com script in the past to convert Illustrator paths to Motion shapes. However, at this time, I no longer have access to Illustrator. I do have Vectordesigner. Are there any alternate means in which an outline of an object can be converted to a Motion shape, so that it can then be treated with Motion's shape behaviors?
Univers Becker
on Dec 20, 2012 at 4:52:41 pm
Where could I find the script, or something to convert it into a shape? for motion 5. all websites are offline?
Mark Spencer
on Dec 20, 2012 at 4:55:04 pm
I'm hosting it now
http://www.applemotion.net/downloads/
Mark Spencer
Luc Fox
on Apr 13, 2016 at 6:14:58 pm
I just made an account after years of lurking to say THANK YOU MARK! You are awesome and your video from 2009 just helped me finish a logo animation the way I needed to. I really appreciate your help and the great content!
Mark Spencer
on Apr 13, 2016 at 8:32:09 pm
You are welcome Luc!
Mark Spencer
Geoff Robert
on Jan 5, 2017 at 3:46:40 am
Hi Mark,
Using the script you are hosting, the export appears to have worked successfully from Illustrator (file 73kb). However, I have been trying to import the shape (ship.motn) into Motion 5. Have tried dragging it into the Shapes Library, Content pane, to a layer, .. anywhere.... even opening it in a new project, but nothing appearing.
What is the right way to get the shape into Motion5?
Geoff
