motin 5 default
COW Forums : Apple Motion
Jim Cunningham
motin 5 default
on Jul 12, 2011 at 12:56:44 pm
I've downloaded Motion 5 to start to check it out on a secondary system. It has become the default version of Motion and if I want to open a previous version project and keep it in Motion 4, I have to manually open Motion 4. Is there a way of making Motion 4 once again the default version?
BTW, I want to especially thank everyone for their responses and insights regarding this unfortunate X situation. I will ultimately need to make some hard decisions in the next few months, and the cumulative wisdom found here will help to make an informed decision.
Jim
David Stembridge
Re: motin 5 default
on Jul 12, 2011 at 5:31:56 pm
I'm with you there... I went ahead and zipped it for now. Look forward to figurin out if I want to go that route, with new x versions and all as well.
Carsten Orlt
Re: motin 5 default
on Jul 15, 2011 at 1:09:17 am
select a motion project in finder > get info > change the 'open with' menu to Motion 4 > select change all
from now on double clicking a motion project opens vers4. Also open in editor from FCP7 opens Motion4
