Adding Tracker in Match Move?
COW Forums : Apple Motion
Grant Gomm
on Jun 15, 2011 at 4:29:42 pm
I'm trying to get a mask to match up with a layer in a different group, but it's a little off. I hoped to add a tracker or two to see if that would match it better. I thought I remembered that there was a way to have multiple trackers with the Match Move behavior. But either I was wrong or I'm overlooking something. Is this possible, and if so, could someone direct me in the right path? Thanks in advance.
-Grant Gomm
http://www.blacklionproductions.com
Simon Ubsdell
Re: Adding Tracker in Match Move?
on Jun 17, 2011 at 10:39:12 am
If you change the Match Move's "Adjust" option to "Scale" or "Rotation" (in the Behaviors tab) you'll get a second tracker.
Or better still, if you change the "Type" from "Transformation" to Four Corners you'll get four trackers that will enable you to corner pin if that's what you need.
Hope that helps.
Simon Ubsdell
Director/Editor/Writer
http://www.tokyo-uk.com
Grant Gomm
on Jun 17, 2011 at 4:19:16 pm
Thanks Simon. I appreciate the help!
-Grant Gomm
