Solid color transparency gradient
COW Forums : Apple Motion
Jack Johnson
on May 19, 2011 at 6:05:13 pm
Is there a way to apply a transparency gradient to a solid color?
Mark Spencer
Re: Solid color transparency gradient
on May 19, 2011 at 6:08:24 pm
Sure. Just change the fill to Gradient and add and adjust opacity tags.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Jack Johnson
on May 19, 2011 at 6:12:17 pm
How do I change the fill on solid color?
Stephen Smith
on May 19, 2011 at 6:15:29 pm
Yes, Select the Shape. Hit F4 to open up the Shape tab. Under the Style tab change the "Fill Mode from Color to Gradient. Make both gradient colors the same. Above where the two colors are you will see a white square. That represents the opacity. To add another square click anywhere above the white rectangle. Then select one of the squares and changes its opacity. See image below:
Other wise you will have to do a blend mode or Image mask. To learn more about that check out this tutorial on creating a Hologram tutorial
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Jack Johnson
on May 19, 2011 at 6:26:50 pm
Thank you sir.
Stephen Smith
on May 19, 2011 at 6:42:20 pm
Happy to help. Best of luck.
Stephen Smith
