Frame blending for the retimed part only?
COW Forums : Apple Motion
Laszlo Jancsik
on Apr 13, 2011 at 12:49:53 pm
I'm trying to speed up the end part of a clip with frame blending ON. It's almost fine, but frame blending is applied to the entire length of the clip, even where it plays back at 100%. Is there a way to avoid that?
I really need the blur on the fast part, but not on the other. Any suggestions are highly appreciated ;)
Gareth Randall
Re: Frame blending for the retimed part only?
on Apr 14, 2011 at 6:52:30 am
Split the clip at the frame where you want the retiming to start and then apply the retiming to just that section.
zak peric
on Apr 14, 2011 at 9:11:16 am
To split the clip you need to do this in the timing pane not a project pane. Select the clip in the timing pane and place a yellow tooltip icon where you want it to split. Then under the edit menu (I think under that menu) use split command.
