best settings: Motion/Compressor to Youtube
COW Forums : Apple Motion
joseph shelley
on Mar 24, 2011 at 9:16:18 pm
Hi all,
Wondering if anyone can suggest settings for Motion and Compressor content that is intended for Youtube.
Been reading up on how to compress Final Cut footage for Youtube. None of the suggested settings seem to come out with Motion footage. Main issue is jagged edges around objects, almost like they were interlaced. Also some compression artifacts, especially in highlights.
here are my settings:
Name: YouTube HQ H264 HD 1080
Description: 1080*1920 full res, square pix
File Extension: .mov
Estimated file size: unknown
Audio Encoder
AAC, Stereo (L R), 44.100 kHz
Video Encoder
Format: QT
Width: 1920
Height: 1080
Pixel aspect ratio: Square
Crop: None
Padding: None
Frame rate: (100% of source)
Frame Controls On:
Retiming: (Best) High quality Motion Compensated
Resize Filter: Statistical Prediction
Deinterlace Filter: Best (Motion Compensated)
Adaptive Details: Off
Antialias: 0
Detail Level: 0
Field Output: Progressive
Codec Type: H.264
Multi-pass: On, frame reorder: On
Pixel depth: 24
Spatial quality: 100
Min. Spatial quality: 25
Key frame interval: 12
Temporal quality: 50
Min. temporal quality: 25
Fast Start: on
About to try this instead:
Estimated file size: 4.29 GB/hour of source
Audio Encoder
Video Encoder
Format: QT
Width: 1920
Height: 1080
Crop: None
Padding: None
Frame Controls On:
Deinterlace Filter: Better (Motion Adaptive)
Antialias: 0
Detail Level: 0
Codec Type: H.264
Pixel depth: 24
Spatial quality: 75
Average data rate: 10.24 (Mbps)
Maximum data rate: 10.24 (Mbps)
Fast Start: on
Jeff Greenberg
Re: best settings: Motion/Compressor to Youtube
on Mar 25, 2011 at 10:46:58 am
I know this is a silly question: have you tried the youtube preset under the File> share menu (or are you using Motion 3?)
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
joseph shelley
on Mar 25, 2011 at 2:24:36 pm
Hi Jeff,
I'm still using Motion 3. You don't happen to have the settings handy in the inspector, do you? if so, is there any way you could copy and paste them for me, so I can check them out?
Any other advice would be welcome.
Thanks for the response,
-Joe
Jeff Greenberg
on Mar 25, 2011 at 3:46:56 pm
Basically, it's an 8mb h.264 in a QuickTime wrapper.
Best,
Jeff G
joseph shelley
on Mar 25, 2011 at 5:05:19 pm
Awesome,
Thanks for the screenshot! I'll see if I can glean anything from it.
Cheers,
-joe
Andy Neil
on Mar 26, 2011 at 4:05:55 pm
Well, what are your source settings? What are you starting with? I use a preset similar to your first setting (frame controls are typically unnecessary for a you tube upload). I do set the bit rate to between 3000 and 6000 kbs.
However, it matters a little what your Motion settings are as well. What is your frame size and frame rate?
Andy
http://www.timesavertutorials.com
