LiveFonts disappear after being applied to text
COW Forums : Apple Motion
Roger Stoneburner
on Mar 10, 2011 at 5:52:45 pm
Pulling what little hair I have left out :)
I've tried adding several different livefonts to text with the same results, the text disappears completely.
I've even solo'd the text layer and added it then, only to see the text disappear. I've scrolled later in timeline with no luck.
Help...
Roger Stoneburner
Re: LiveFonts disappear after being applied to text
on Mar 10, 2011 at 6:33:25 pm
is it possible livefonts are not loaded on my comp but the icons still show in Motion?
anyone?
Jimmylee Remillard
on Mar 11, 2011 at 2:02:07 pm
Im pretty sure the problem is the loop setting. When you go into the inspector tab, then text tab, then format.. All the way at the bottom you will see live font settings. Its most likly the loop is not set to a high enough number. Remeber livefonts are video files being played as text.
Micah DeBenedetto
on Apr 10, 2011 at 6:14:07 pm
thank you.
