Drop Zones - custom shapes and gradients...
COW Forums : Apple Motion
Adam Heayberd
on Mar 7, 2011 at 2:02:25 pm
I need to make a few drop zones that I need to play a few seconds of media.
The look I need however, is a small series of squares, that have a red gradient applied over the top as it will just feature as a backdrop to some text.
Any walkthrus as to how I apply a custom mask with gradient and feather to a drop zone?
A
Editor & Self Shooter in the UK
http://www.aheayberd.tumblr.com
http://www.twitter.com/adamheayberd
Adam Heayberd
Re: Drop Zones - custom shapes and gradients...
on Mar 7, 2011 at 2:33:20 pm
Hi guys...
More specifically, the look I would like to achieve is this:
(apologies for quality, a friend recorded it on their iphone...)
WRC titles
Any ideas/tutorials?
Adam
Stephen Smith
on Mar 7, 2011 at 2:45:41 pm
This is what it looks like to me.
Bottom layer - Clip (drop Zone)
All layers above the drop zone are the eight squares set to a gradient that fade on at different times and cover up parts of the bottom layer. Text then goes above that.
Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Andy Neil
on Mar 7, 2011 at 4:56:02 pm
Here's what I'd do. Create your dropzone. On top of that create a rectangle with a red gradient. Then create a square shape and make a replicator out of it so you can have the 8-square pattern that you see in your video. Add an image mask to your red rectangle and use the replicator as the source for the rectangle. Duplicate the replicator and apply the duplicate as the image mask for the drop zone.
Then you can add a sequence replicator to the source layer for the rectangle's image mask and using the parameters adjust the opacity of some of the squares so that the drop zone below shows through.
Andy
http://www.timesavertutorials.com
Adam Heayberd
on Mar 7, 2011 at 5:31:50 pm
Cool. Thanks guys.
I was trying to over complicate things in the end. So yes, one drop zone placed behind the squares set to different gradients etc worked.
Looks alright if a bit retro!
Cheers
Adam
