sending alpha channel to motion
COW Forums : Apple Motion
Roger Stoneburner
on Mar 4, 2011 at 4:25:51 pm
having a problem with motion identifying an alpha channel in a clip.
i have created the alpha channel in FCP, alpha set to 'straight', i've keyed out a white background from the video clip, and in the canvas you can see the checkerboard surrounding my subject (instead of white bg).
when i export and open in Motion, the channel is no longer Alpha.
i've tried exporting with the ProRes 4444 codec and the animation codec with the same results.
anyone?
Stephen Smith
Re: sending alpha channel to motion
on Mar 4, 2011 at 4:28:16 pm
Make sure the clip is not rendered in FCP.
Set codec to "Millions Color +" The plus is the transparency.
Best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Roger Stoneburner
on Mar 4, 2011 at 4:39:54 pm
Bingo! Thanks, Stephen. That worked great.
Stephen Smith
on Mar 4, 2011 at 5:45:43 pm
Awesome, best of luck.
Stephen Smith
Roger Stoneburner
on Mar 4, 2011 at 6:30:48 pm
Stephen,
Have another question for you.
I'm having a strange anomaly exporting a file with this alpha channel, using the animation codec.
I've exported a few clips with no problems, but there's one clip, that it truncates the front end off for some odd reason, a sentence. Very odd that it cuts off the front end and not the back end. I exported it using the ProRes codec and it came through fine (no alpha channel), so it has something to do with that codec i'm assuming. i've changed the in point, new sequence, moved further down timeline, extended the clip, all with no luck.
i'm baffled.
oh yeah, i also re-started FCP and no change.
Roger Stoneburner
on Mar 4, 2011 at 6:36:17 pm
redacted: it is truncating the front end off all the clips, maybe 3 or 4 seconds?
Stephen Smith
on Mar 4, 2011 at 7:04:24 pm
You have in and out points marked on the FCP time line right?
Stephen Smith
Roger Stoneburner
on Mar 4, 2011 at 7:10:47 pm
yes, beginning and end of clip.
Roger Stoneburner
on Mar 4, 2011 at 7:24:12 pm
ha ha. I was saying, yes, i've got the correct in an out points in the timeline :)
it's now cutting off the beginning of the first word, even if i extend the clip to it's beginning and the timeline "in" point to reflect the change. argh. think this is a bug of some sort.
Roger Stoneburner
on Mar 4, 2011 at 7:35:45 pm
One thing, I'm not rendering the clip before export, per another thread I read on here. should I be rendering first?
Stephen Smith
on Mar 4, 2011 at 7:45:11 pm
Humm, this sounds very strange. I've never experienced this. I'm not sure why it is not exporting the whole clip. Sorry, I'm not sure what to do. I think it is weird that it worked earlier and then all of the sudden it doesn't.
If you want a transparent background then don't render it. When you render it FCP places black in the background so it is no longer transparent.
Stephen Smith
Roger Stoneburner
on Mar 4, 2011 at 7:34:18 pm
now I'm having another anomaly where the image won't show up after exporting with the codec, wt heck? i'm not exporting any different. i only have 8GB of ram (on macbook pro), hope that's not the issue. seems to be going a bit wonky.
Roger Stoneburner
Re: figured out problem
on Mar 5, 2011 at 3:42:16 pm
was with the timing. the FPS didn't match the project settings.
Stephen Smith
on Mar 7, 2011 at 2:26:19 pm
Oh, good. I'm glad you figured it out and posted it so when others read this thread they will see the solution to the problem.
Stephen Smith
