How do you achieve this motion? (pictures included)
COW Forums : Apple Motion
Holden Kim
on Feb 28, 2011 at 7:09:50 pm
Hi everyone,
I've tried to mimic this animation by 'adding image mask' to the text image, and also by masking out dropzone, 'rectangle mask tool' on dropzone but no luck. When it's applied with 'sequence replicator', each tiles rotate as I wanted but the text image just sits there and doesn't rotate. I don't know what I'm doing wrong here. Am I missing something? Can anybody help me with this? If you could be elaborate, I'd appreciate it. Thanks!
H
Holden Kim
Re: How do you achieve this motion? (pictures included)
on Feb 28, 2011 at 7:21:54 pm
OK. So I tried again, now by 'making clone layer' of the original drop zone which later I dropped the text image onto, and now the text image rotates together when I rotate each tiles. (YES!) But then, do I have to animate each tiles to rotate or is there a way I can animate them to rotate all at the same time like I would do with 'sequence replicator'? Thanks for the help!
H
