Adding Behavior to Text kills 3D
COW Forums : Apple Motion
Andrew Wilson
on Feb 25, 2011 at 7:39:13 pm
I have a light streak that wraps around a text element so text is inside the loop of the light streak.
problem is that once I apply any kind of behavior or adjust the opacity to the text element, the 3d layering goes away. I want the text to appear softly when the streak goes around it. like a soft edged wipe or, heck, even a fade up would be okay.
Thanks....
Andrew Wilson
WestView Digital Video & Design
http://www.westviewdigital.com
Mark Spencer
Re: Adding Behavior to Text kills 3D
on Feb 25, 2011 at 7:41:56 pm
What you are seeing is that the behavior or the opacity change is forcing the text to become rasterized, and therefore composited in layer order. That's what the little box that shows up around the icon means - and the blue LED next to the Opacity parameter in the Inspector.
Try animating the Face Opacity of the text with a sequence text behavior - face opacity changes don't trigger rasterization like layer opacity does.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Andrew Wilson
on Feb 25, 2011 at 8:02:00 pm
Awesome workaround. Thanks much!
I actually prefer animating the face blur and opacity now that I know how.
Andrew Wilson
