text export to FCP
COW Forums : Apple Motion
Patrick Paulson
text export to FCP
on Feb 24, 2011 at 4:08:14 pm
I have created text in Motion (color w a grey drop shadow). I have selected "alpha+color" for the export.
Back ground is "transparent" in my canvas. When I bring it in to FCP and try to super it over my video on track one, I get my text with a solid black backround...no superimpose. What am I missing here?
Thanks for your help.
Patrick
Stephen Smith
Re: text export to FCP
on Feb 24, 2011 at 4:13:03 pm
Make sure in Motion you don't have a solid background. To do this go up to Edit, Project Properties. Change the Background option to "Transparent".
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Patrick Paulson
on Feb 24, 2011 at 4:22:07 pm
background is transparent
Dave Davin
on Feb 24, 2011 at 4:27:40 pm
Hey Patrick
You could just save the Motion project and import the motion file into FCP without exporting it.
That should work.
Dave
Dave Davin
Creative Director
RAIC Productions
http://www.raicproductions.com
Patrick Paulson
on Feb 24, 2011 at 4:33:29 pm
Hi Dave, thanks for the response. I want to have control of my video and text (gfx) independent of each other (video on track one gfx on track two). If I "round trip" it from FCP to MOTN then what I get is my text and video together on one channel.
When I export and select only "alpha" instead of "color+alpha" I get my text and my shadow, of course I no longer have the color, just white text and white shadow. I can't figure out why it's not sending me my color text with the shadow in a format that will super right over the video channel when I select "color+alpha".
Stephen Smith
on Feb 24, 2011 at 4:37:09 pm
If you want to Export it out Set It to QuickTime's Animation codec. Make sure it is set to Millions Color +. The plus stands for the transparency you want. You can also use ProRes 4444. Best of luck and hope this helps.
Stephen Smith
Patrick Paulson
on Feb 24, 2011 at 4:39:10 pm
I'll give that I try...heading out now, but as soon as I get back. I'll let you know how that works.
Stephen Smith
on Feb 24, 2011 at 4:40:36 pm
Sounds great.
Stephen Smith
Patrick Paulson
on Feb 24, 2011 at 9:08:07 pm
Thanks Stephen! That works. Jeff also pointed out that Pro Res 4444 will work and it did.
Thanks again.
Jeff Greenberg
on Feb 24, 2011 at 5:01:42 pm
Likely your export isn't sending out the alpha channel.
Millions of Colors + (The plus is what we need).
Animation or ProRes 4444 codecs. Nothing else.
Best,
Jeff G
Apple Master Trainer
Avid Cert. Instructor DS/MC
Avid & Color Videos Vasst.com
Compressor Essentials Lynda.com
Patrick Paulson
on Feb 24, 2011 at 9:07:08 pm
Thanks Jeff,
Both Animation and 4444 work as expected. I was trying to export in Pro Res 422 (timeline setting) and no luck...Now I know. Thank you.
