Motion text isnt working...
COW Forums : Apple Motion
Adam Heayberd
on Feb 22, 2011 at 12:29:25 pm
Hi
Any ideas...when I create text in motion, it doesnt show. So I used another machine with motion, got the text on it and then saved that motion project and opened it on the other mac computer where the text wasnt responding.
Anyway, it opened fine but when I went to the text inspector to change it, it stalled motion and then shut it down.
Has this happened to anyone? Is there something I can do? I have the install discs...should I re-install motion???
Adam
Editor & Self Shooter in the UK
zak peric
Re: Motion text isnt working...
on Feb 22, 2011 at 5:23:11 pm
Delete the preferences of Motion. They are in your library/preferences look for Motion preferences and delete. Restart your motion you should be fine.
See this article:
http://support.apple.com/kb/HT1885
Good Luck
Kate Galbincea
on Feb 22, 2011 at 10:51:08 pm
I have been having the same problem - found this forum that seems to have answer:
http://discussions.apple.com/thread.jspa?messageID=12537058
it appears that installing the ProKit update 6.0.1 fixes the problem.
Adam Heayberd
on Feb 22, 2011 at 11:01:02 pm
I discovered that thread shortly before you posted it!!
Sure enough the update did fix the problem.
Thank you very much!
A
