motion path...
COW Forums : Apple Motion
Adam Heayberd
motion path...
on Feb 22, 2011 at 9:54:04 am
Hi
I need a pointer on creating a motion path. I need a flag to come in behind a subject within the first 10 frames at high speed, coming in from left (off camera) to right, ending behind the subject and staying there for a few seconds, then to fly off to the right off screen within the last 20 frames.
Im having a nightmare of a time trying to get the motion path right and need some pointers!!!
Many thanks.
Adam
Editor & Self Shooter in the UK
zak peric
Re: motion path...
on Feb 22, 2011 at 5:25:41 pm
You can not achieve this with behaviors, however this is a simple animation that can be key-framed easily.
Go to the properties of your object and animate the position parameter of the object. Then in the key-frame editor you can change the interpolation of the animation.
Good Luck
