Composite video
COW Forums : Apple Motion
Chad MacKenzie
Composite video
on Feb 21, 2011 at 11:34:29 pm
I just saw this the other on tv, but there was a shot of a man walking into a room and the shot froze and the everything in the back ground turned black and white while the man was still in his full color while frozen.
Do they achieve this by having two of the same videos playing (but one video has the man cut out and the back ground is black and white) and at the moment you want that look you just freeze the shot?
Stephen Smith
Re: Composite video
on Feb 22, 2011 at 12:18:44 am
You take the clip and slow it down with a behavior or keyframes. Then you duplicate the clip. Use the mask tool on the top clip to create a mask around the person. Then on the bottom clip add a desaturate filter to make it turn from color to black and white. Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
