Multiple output ratios
COW Forums : Apple Motion
Mick Haensler
on Feb 7, 2011 at 1:22:58 pm
Hey everyone. I have a client that needs final product to be in both 16:9 HD and 4:3 SD, is there an easy way in Motion to get this done? It's for a HD DS network but also needs to be shown on 2 SD LED boards. I usually render out to H264 which can be used by both the network and the software controlling the boards. Problem is, content on the boards is letterboxed when broadcast. No big deal except that the boards aren't big enough for the application as it is and letterboxing makes things even smaller. I need an easy solution to this as I'm on a tight budget. Thanks in advance for any ideas.
Mick Haensler
Higher Ground Media
Peter Wiggins
Re: Multiple output ratios
on Feb 7, 2011 at 2:55:40 pm
Just make everything in HD first (being careful to frame stuff so that it won't get cutoff in 4:3) and then convert those files to SD 4:3 in compressor.
Peter
Mick Haensler
on Feb 7, 2011 at 3:18:52 pm
DUH!!!
Thanks Peter. As my high school Latin teacher would say when pointing out the obvious. "Congratulations, you now have dee fort corner of dee bed sheet"!!(He was Russian). Easy and fast solution...
Mick Haensler
Higher Ground Media
