Clip to slideshow
COW Forums : Apple Motion
federico betta
Clip to slideshow
on Jan 12, 2011 at 11:10:01 am
Hi to all ng,
I don't know how to ask my matter in the search toolbar...
I've a clip and I need to transform it in a slideshow with a group of clip's frames (a frame every x seconds)
I've explayned my question?
It is possible by effect or a third part plugin?
sorry for my awful english :(
thanks
Federico
Stephen Smith
Re: Clip to slideshow
on Jan 12, 2011 at 1:43:11 pm
iPhoto can do slide shows on photos real easy. You can time it to music or tell it how long it should be. They have templates to choose from. It is very cool.
If you want to do it in Motion then give CoverFlux a try.
Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
federico betta
on Jan 12, 2011 at 2:15:36 pm
thanks...
but maybe my english is too poor to explain my problem
I've a video clip and I need to do a slideshow with its frames (the slideshow will be composed by a frame every 1 second of the video clip... video is 1 minute long and the slideshow will be realized with 60 photo)
in short I've to export a still frame every 1 second from my video clip (and then I know how to use iphoto...)
thank you
federico
Stephen Smith
on Jan 12, 2011 at 2:28:18 pm
Sorry, I mis-understood. To export a still frame land your play head on the frame and then go up to File, Export. Change Export from QuickTime Movie to Current Frame. If you want to change it from a .tiff to something else then click on the Options button. Hope this helps and best of luck.
Stephen Smith
federico betta
on Jan 12, 2011 at 5:18:03 pm
thanks stephen
but ;)
I wish to export a still frame every 1 second from my video clip ... !automatically!
sorry for incomprete thread
federico
Andy Neil
on Jan 13, 2011 at 1:06:07 am
The easiest way to do that is to export your video clip as an image sequence in Quicktime Pro. Then delete all the unnecessary images from the resulting sequence.
Andy
http://www.timesavertutorials.com
Stephen Smith
on Jan 13, 2011 at 3:15:00 pm
Instead of QuickTime Pro, export out an image sequence in Motion. Do the following:
File, Export. Change Export from "QuickTime Movie" to "image sequence". Click on the options button to change the type of still you want.
Best of luck.
Stephen Smith
federico betta
on Jan 13, 2011 at 3:25:31 pm
WOW!
If I select a frame every second is like I need.
thank you!
Federico
