Kinetic Typography Tutorial
COW Forums : Apple Motion
Stephen Smith
on Jan 4, 2011 at 4:56:59 pm
Take a look at this Apple Motion video tutorial, by CreativeCOW.net contributing editor Stephen Smith who will show you how to get your text noticed. This tutorial shows you the ins and outs of kinetic typography, otherwise known as moving text. Plus, Stephen will take you beyond just learning how to use Motion and show you key text characteristics.
http://library.creativecow.net/smith_stephen/Apple-Motion_Kinetic-Typograph...
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Gabe Strong
Re: Kinetic Typography Tutorial
on Jan 5, 2011 at 7:28:04 pm
Nice job, I really like this tutorial....always meant to learn how
to do that 'type' of TV spot that you always see nowdays, after
watching this tutorial I now know how. By the way,I've got both your
'Money Making Graphics and Effects' and 'Moving with Motion'
DVD's and they are both really good as well.
Gabe Strong
G-Force Productions
http://www.gforcevideo.com
Stephen Smith
on Jan 5, 2011 at 10:17:20 pm
Gabe,
Thanks for the kind words, they made my day. Also, thanks for supporting the COW.
Stephen Smith
Julian Gomez
on Jan 19, 2012 at 11:42:31 pm
This is the best *free* tutorial for kinetic typography on Apple Motion that I've found yet. It's really good at going step by step in an easy to understand format.
I've got the basics down thanks to this, I only wish I knew how to do a little more, like all the animations I see in kinetic typography videos that aren't words.
Stephen Smith
on Jan 20, 2012 at 12:06:27 am
Julian,
Be sure to check out this kinetic typography video I did, I think it turned out very well.
Is there a sample of an animation that you are trying to create?
Stephen Smith
Check out my Vimeo page
Julian Gomez
on Jan 20, 2012 at 12:17:23 am
Very nice video indeed! The animations I mean are for example different colored people, or band-aids, or the Earth you used. Are those just images/videos that you got and chroma keyed or something to use?
I am keen on learning how to do kinetic typography for a promo for a benefit concert I am trying to help plan to help victims of rape in Congo.
Thank you for the quick reply, by the way!
Stephen Smith
on Jan 20, 2012 at 12:27:40 am
Yes, they are illustrator files and the earth was created in a 3D program. I didn't move any of those objects. I laid them out with the text and animated the people's silhouette scale to have them pop in. Then I used the camera to fly from one set of text to the other, that way the band-aids, globe and silhouettes just animated with the text. Hope this helps and best of luck with your promo.
Stephen Smith
Julian Gomez
on Jan 20, 2012 at 12:37:17 am
It did, thank you very much for your time!
Nathan Nicoara
on Jan 25, 2012 at 3:18:53 am
At the point in the tutorial where it stops, how do you reanimate the camera to zoom in on the word "on"? Do you need to create a new camera?
Stephen Smith
on Jan 25, 2012 at 5:10:37 pm
I always use one camera in Motion. If you watch the Mark Twain quote the whole quote is very fluid. When I can I like to break my Motion project up into segments and "glue" them together in Final Cut Pro. For example, this TV show open I did is multiple Motion projects. When the camera flies to Erin that is one project cut to another because this project was so heavy it started eating up my real time playback capabilities so I looked for ways to make one project multiple projects and then string them together in FCP. Hope this helps and best of luck.
Stephen Smith
