Motion 4 re-load
COW Forums : Apple Motion
charles walker
Motion 4 re-load
on Dec 24, 2010 at 5:04:02 am
I successfully loaded FCPS3 on my Imac -3.3ghz with 14 gb ram. After several months, it became necessary to delete & re-load Motion. After reloading and receiving"installation successful" message, I tried to execute the program. To my surprise, the Motion application was not in the applications folder. I then reloaded the Motion package 4 more times - with the same result of not finding the loaded application. No where on the applications drive does the program exist, after the "installation successful" form is posted. I am totally baffled about this. Does anyone in the forum have any ideas - or have experienced & solved this anomaly in the past????
Noah Kadner
Re: Motion 4 re-load
on Dec 25, 2010 at 2:18:00 am
Should work fine- we're talking original install disc and legit registration code? If it still refuses to work, call up Apple and get service.
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Canon 5D Mark II and 7D.
zak peric
on Dec 26, 2010 at 10:47:54 am
Have you tried installing the FCS to a new user on your mac, maybe there is something wrong in your user account yu are using. Create a fresh account and try installing it again. Also you can try to delete all FCS associated files then try to install it again.
see this app: http://www.digitalrebellion.com/fcs_remover.htm
or see this: http://discussions.apple.com/thread.jspa?messageID=3148496�
or this:http://appzapper.com/
or this: http://www.matterform.com/mac_software/uninstaller/index.html
best of luck
