3D Issues with Groups
COW Forums : Apple Motion
Andree Franks
on Dec 19, 2010 at 4:09:55 pm
I am having a little issue with my Comp in Motion.
Let try explain this... :o/
When you have a comp in 2D, he Group on top will cover the one underneath (in the layers) right.
But when I change the comp to 3D and move the Group in the Z space (-700 for example). the Group that is above the other but in a negative Z space still is covering other group.
Did I miss something or is just Motion Buggy again?
Mark Spencer
Re: 3D Issues with Groups
on Dec 19, 2010 at 4:13:23 pm
If your group is being rasterized (has a square around the 3D group icon) it will be composited in layer order, not z-depth. Things that can cause this are opacity changes, blend modes, and certain filters - usually the offending parameter has a blue dot next to it in the Inspector.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Andree Franks
on Dec 19, 2010 at 4:20:12 pm
Ha thats what was the issue! How do I un-rasterize the group?
Mark Spencer
on Dec 19, 2010 at 4:27:40 pm
Remove whatever is causing the rasterization
Mark Spencer
