Crashes when I import Generator content
COW Forums : Apple Motion
Robert Phillips
on Dec 4, 2010 at 3:07:02 pm
Good morning
I'm having some weird behavior happen whenever I import "Generator" content. Whenever I add content to the project, I get the spinning beach ball of doom.
The error is posted below. Can anyone share insight on what's going on? I would appreciate it greatly! I'm using Motion 4 on a Mac Pro OS 10.5.8
2.8 GHz Quad Core Intel Xeon
4 GB 800 MHz DDR2 FB-DIMM
error message:
Date/Time: 2010-12-04 08:57:28 -0500
OS Version: 10.5.8 (Build 9L30)
Architecture: i386
Report Version: 4
Command: Motion
Path: /Applications/Motion.app/Contents/MacOS/Motion
Version: 4.0.3 (729)
Build Version: 62
Project Name: Motion
Source Version: 7290000
Parent: launchd [141]
PID: 15039
Event: hang
Time: 7.05s
Steps: 46
Process: Motion [15039]
ADDRESS BINARY
00001000 /Applications/Motion.app/Contents/MacOS/Motion
00143000 /Library/Application Support/ProApps/SharedA/Frameworks/ProInspector.framework/Versions/A/ProInspector
0019c000 /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
001b5000 /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Helium
002c4000 /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
00588000 /Applications/Motion.app/Contents/MacOS/../Frameworks/AERegistration.framework/Versions/A/AERegistration
005ab000 /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProMath.framework/Versions/A/ProMath
005ce000 /Applications/Motion.app/Contents/MacOS/../Frameworks/AEProfiling.framework/Versions/A/AEProfiling
005df000 /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProMedia.framework/Versions/A/ProMedia
007b8000 /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
00895000 /Library/Frameworks/XSKey.framework/Versions/A/XSKey
008c2000 /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
008d3000 /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
008d8000 /Library/Application Support/ProApps/SharedA/Frameworks/FxHeliumImage.framework/Versions/A/FxHeliumImage
00d83000 /Library/Application Support/ProApps/SharedA/Frameworks/Motion/Ozone.framework/Versions/A/Ozone
01b06000 /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProGraphics.framework/Versions/A/ProGraphics
01c8d000 /Library/Application Support/ProApps/SharedA/Frameworks/Lithium.framework/Versions/A/Lithium
01e98000 /Library/Application Support/ProApps/SharedA/Frameworks/ProChannel.framework/Versions/A/ProChannel
02005000 /System/Library/Frameworks/Python.framework/Versions/2.5/Python
0211e000 /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
021a2000 /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
021d7000 /Library/Frameworks/FxPlug.framework/Versions/A/FxPlug
021fb000 /usr/lib/libedit.2.dylib
0221c000 /Library/Application Support/ProApps/SharedA/Frameworks/Motion/RetimingMath.framework/Versions/A/RetimingMath
02242000 /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
023ed000 /usr/lib/libexpat.1.dylib
02459000 /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
06647000 /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
067fa000 /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLDriver
07c24000 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
07c46000 /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Text.ozp/Contents/MacOS/Text
07cd4000 /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
07d50000 /Library/Frameworks/DivX Toolkit.framework/Versions/A/DivX Toolkit
07d58000 /Library/QuickTime/Motion.component/Contents/MacOS/Motion
07da4000 /Library/Frameworks/Motion.framework/Versions/A/Motion
07dac000 /Library/QuickTime/macam.component/Contents/MacOS/macam
07f23000 /Library/Application Support/ProApps/SharedA/Frameworks/Motion/Bloodhound.framework/Versions/A/Bloodhound
07fb1000 /Library/Plug-Ins/FxPlug/Lock & Load X.fxplug/Contents/MacOS/Lock & Load X
07ff3000 /Library/Application Support/ProApps/Internal Plug-Ins/FxMetaPlug/ImageUnit.fxmetaplug/Contents/MacOS/ImageUnit
07fff000 /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
08017000 /usr/lib/libmx.A.dylib
08026000 /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
08035000 /Library/Plug-Ins/FxPlug/Lock & Load.fxplug/Contents/MacOS/Lock & Load
08077000 /Library/Plug-Ins/FxPlug/VTwinFx.fxplug/Contents/MacOS/VTwinFx
08200000 /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Behaviors.ozp/Contents/MacOS/Behaviors
08436000 /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Particles.ozp/Contents/MacOS/Particles
0862f000 /Library/Application Support/ProApps/SharedA/Frameworks/Motion/TextFramework.framework/Versions/A/TextFramework
08aa0000 /Library/Frameworks/PixlockCVL.framework/Versions/A/PixlockCVL
08c3f000 /Library/QuickTime/AppleProResCodec.component/Contents/MacOS/AppleProResCodec
09200000 /Library/QuickTime/Blackmagic Codec.component/Contents/MacOS/Blackmagic Codec
0930c000 /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
0975b000 /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
097a2000 /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
09879000 /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
09899000 /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
098be000 /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
098dc000 /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
098ef000 /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
0996e000 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0999e000 /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
099aa000 /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
09a1e000 /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
09a66000 /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
09b42000 /Library/QuickTime/iChatTheaterPreview.component/Contents/MacOS/iChatTheaterPreview
09b56000 /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
09b69000 /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/Resources/LeopardPanels.bundle/Contents/MacOS/LeopardPanels
09ba8000 /Library/InputManagers/Cooliris/Cooliris.bundle/Contents/MacOS/Cooliris
09bb2000 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
09e1d000 /Applications/Motion.app/Contents/Resources/MRCheckPro.bundle/Contents/MacOS/MRCheckPro
0defa000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0ec53000 /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense
0ec69000 /Library/QuickTime/AppleAVCIntraCodec.component/Contents/MacOS/AppleAVCIntraCodec
0f000000 /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
0f400000 /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
0f605000 /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
10000000 /Applications/Motion.app/Contents/MacOS/../Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
200f3000 /System/Library/PrivateFrameworks/Helium.framework/Versions/A/Helium
20c42000 /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Plug-ins/HCache.bundle/Contents/MacOS/HCache
2140d000 /Applications/Motion.app/Contents/PlugIns/FxPlug/SmoothCam.fxplug/Contents/MacOS/SmoothCam
21419000 /System/Library/PrivateFrameworks/Helium.framework/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
21800000 /Applications/Motion.app/Contents/PlugIns/FxPlug/Filters.bundle/Contents/MacOS/Filters
ba900000 /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
Thread id: f239790
User stack:
46 ??? [0x2746]
46 ??? [0x55de]
46 _NSProApplicationMain + 325 (in ProKit) [0x2e714c]
46 -[NSApplication run] + 867 (in AppKit) [0x95207fe7]
46 ??? [0x839b]
46 -[NSApplication sendEvent:] + 2939 (in AppKit) [0x952aa6a5]
46 -[OZDocumentWindow sendEvent:] + 90 (in Ozone) [0x105e9ea]
46 -[NSProWindow sendEvent:] + 273 (in ProKit) [0x309009]
46 -[NSWindow sendEvent:] + 5381 (in AppKit) [0x952ddaf7]
46 -[NSControl mouseDown:] + 888 (in AppKit) [0x952df3b8]
46 -[NSProButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 288 (in ProKit) [0x3218b5]
46 -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 541 (in AppKit) [0x952dfafe]
46 -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 1827 (in AppKit) [0x952e02ab]
46 -[NSCell _sendActionFrom:] + 169 (in AppKit) [0x952e0c52]
46 -[NSControl sendAction:to:] + 108 (in AppKit) [0x952e0dcc]
46 -[NSProApplication sendAction:to:from:] + 124 (in ProKit) [0x2e64cb]
46 -[NSApplication sendAction:to:from:] + 112 (in AppKit) [0x952e0e8f]
46 -[OZCanvasView pause:] + 46 (in Ozone) [0x131f05e]
46 -[OZGLViewer doPause] + 695 (in Ozone) [0xdcd397]
46 __ZN15OZRenderManager5abortEbj + 195 (in Ozone) [0xf0f983]
46 __ZN21OZRendererBuilderUnit5abortEb + 24 (in Ozone) [0x13c29e8]
46 __ZN15OZExecutionUnit9abortWaitEv + 124 (in Ozone) [0x108cb0c]
46 __ZN11PCSemaphore4waitEv + 45 (in ProCore) [0x7dfebf]
46 ___semwait_signal + 10 (in libSystem.B.dylib) [0x90dd344e]
Kernel stack:
1 _i386_astintr + 47 [0x1aa272]
1 _ast_taken + 247 [0x129472]
1 _bsd_ast + 721 [0x384ced]
1 _postsig + 351 [0x383274]
1 _exit1 + 392 [0x377b31]
1 _task_terminate_internal + 313 [0x13bb81]
1 _vm_map_remove + 145 [0x16b18d]
1 _vm_map_simplify + 4131 [0x16abc5]
1 _pmap_remove_range + 612 [0x194f39]
Thread id: c7d54f0
User stack:
45 _thread_start + 34 (in libSystem.B.dylib) [0x90dfd012]
45 __pthread_start + 321 (in libSystem.B.dylib) [0x90dfd155]
45 __Z11CMMConvTaskPv + 54 (in ColorSync) [0x97787d4e]
45 __Z20pthreadSemaphoreWaitP18t_pthreadSemaphore + 42 (in ColorSync) [0x977753f8]
45 ___semwait_signal + 10 (in libSystem.B.dylib) [0x90dd344e]
Thread id: d3f78b8
User stack:
Thread id: d3f74f0
User stack:
Thread id: cdcd4f0
User stack:
45 _glvmDoWork + 162 (in libGLProgrammability.dylib) [0x91729b32]
Thread id: f23a6b0
User stack:
45 __ZN3AVS26DestroyAVCDeviceControllerEPNS_19AVCDeviceControllerE + 317 (in DVCPROHDMuxer) [0x990698f]
45 _CFRunLoopRun + 84 (in CoreFoundation) [0x95f5bb04]
45 _mach_msg_trap + 10 (in libSystem.B.dylib) [0x90dcc266]
Thread id: c5c4000
User stack:
45 __ZN9CAPThread5EntryEPS_ + 96 (in CoreAudio) [0x93dc1480]
45 __ZN10HALRunLoop9OwnThreadEPv + 160 (in CoreAudio) [0x93dc15f8]
45 _CFRunLoopRunInMode + 88 (in CoreFoundation) [0x95f5baa8]
Thread id: d71fba0
User stack:
45 _PrivateMPEntryPoint + 56 (in CarbonCore) [0x97100fbb]
45 __ZN23TSystemNotificationTask26SystemNotificationTaskProcEPv + 123 (in DesktopServicesPriv) [0x96da4d0f]
Thread id: eb6ca78
User stack:
45 __ZN25TFSEventsNotificationTask28FSEventsNotificationTaskProcEPv + 216 (in DesktopServicesPriv) [0x96da4e88]
Thread id: f23dba0
User stack:
45 __ZN13TNodeSyncTask12SyncTaskProcEPv + 84 (in DesktopServicesPriv) [0x96dafe6a]
45 _MPWaitOnQueue + 208 (in CarbonCore) [0x97102a60]
45 _TSWaitOnConditionTimedRelative + 202 (in CarbonCore) [0x970e1c36]
45 _TSWaitOnCondition + 126 (in CarbonCore) [0x97102de3]
Thread id: 7c59f20
User stack:
45 ___select + 10 (in libSystem.B.dylib) [0x90e1b6fa]
Thread id: c7d2790
User stack:
45 _ReadSchedulerThreadEntryPoint + 4728 (in QuickTimeComponents) [0x91daedf6]
45 _TSWaitOnSemaphoreCommon + 422 (in CarbonCore) [0x970e1a42]
45 _TSWaitOnConditionTimedRelative + 246 (in CarbonCore) [0x970e1c62]
45 _semaphore_timedwait_signal_trap + 10 (in libSystem.B.dylib) [0x90dcc2c6]
Thread id: d3f52e8
User stack:
45 _QTSurfaceRendererScheduledDisplayThread + 158 (in QTKit) [0x91ca3e52]
Thread id: d3f87d8
User stack:
45 _QTVisualContextImageProviderWorkLoop + 122 (in QTKit) [0x91c9d70a]
Thread id: eb6f048
User stack:
45 _IcpDecompressorComponentDispatch + 1771 (in AppleProResCodec) [0x8c4940b]
45 _semaphore_wait_signal_trap + 10 (in libSystem.B.dylib) [0x90dcc2ae]
Thread id: 8c02000
User stack:
Thread id: 7c5c8b8
User stack:
Thread id: d3f5e40
User stack:
Thread id: d71ce40
User stack:
45 ___NSThread__main__ + 308 (in Foundation) [0x913329a4]
45 -[NSThread main] + 45 (in Foundation) [0x91332dfd]
45 -[NSUIHeartBeat _heartBeatThread:] + 753 (in AppKit) [0x952756e8]
45 -[NSConditionLock lockWhenCondition:] + 69 (in Foundation) [0x91378b35]
45 -[NSConditionLock lockWhenCondition:beforeDate:] + 144 (in Foundation) [0x91378bd0]
45 -[NSCondition waitUntilDate:] + 236 (in Foundation) [0x91378dbc]
Thread id: cdce048
User stack:
45 __ZN8PCThread7startupEPv + 18 (in ProCore) [0x7e00a8]
45 __ZN15OZExecutionUnit18executeLoopWrapperEPv + 94 (in Ozone) [0x108cede]
45 __ZN15OZExecutionUnit11executeLoopEv + 75 (in Ozone) [0x108cddb]
Thread id: cdcd128
User stack:
45 __ZN15OZExecutionUnit11executeLoopEv + 197 (in Ozone) [0x108ce55]
45 __ZN12OZRenderUnit7executeEv + 188 (in Ozone) [0x108f66c]
45 __ZN12OZRenderUnit24processRenderInstructionEP19OZRenderInstruction + 2312 (in Ozone) [0x108ed58]
45 __ZN10GLRenderer6renderEP7OZSceneR14OZRenderParams + 4132 (in Ozone) [0x10557d4]
45 __ZN10GLRenderer27findOrCreateRendererBuilderEP7OZSceneR14OZRenderParamsb + 780 (in Ozone) [0x10527bc]
45 __ZN11PCSemaphore4waitEv + 45 (in ProCore) [0x7dfebf]
Thread id: d3f5a78
User stack:
Thread id: d3f4000
User stack:
Thread id: d3f6208
User stack:
45 __ZN21OZRendererBuilderUnit7executeEv + 25 (in Ozone) [0x13c3969]
45 __ZN21OZRendererBuilderUnit24processRenderInstructionEP28OZRendererBuilderInstruction + 1412 (in Ozone) [0x13c3434]
45 __ZN10GLRenderer12getFrameNodeEP7OZSceneR14OZRenderParamsP10HGRendererPl + 164 (in Ozone) [0x10515c4]
45 __ZN10GLRenderer27getFrameNodeIncludingFieldsEP7OZSceneR14OZRenderParamsP10HGRendererPl + 999 (in Ozone) [0x1050c47]
45 __ZN10GLRenderer25getFrameNodeForSingleTimeEP7OZSceneR14OZRenderParamsP10HGRendererddPl + 940 (in Ozone) [0x105002c]
45 __ZN10GLRenderer25getSceneHeNodeFromLiWorldEP7OZSceneRK15OZSceneSettingsR14OZRenderParams5PCPtrI7LiGroupEP10HGRendereriiddPl + 2312 (in Ozone) [0x104a428]
45 __ZN7LiAgent9getHeliumEP13LiImageSource + 4789 (in Lithium) [0x1d79895]
45 __ZN10LiRenderer9getHeliumER7LiAgent + 51 (in Lithium) [0x1d106e3]
45 __ZN16LiRenderInstance9getHeliumER7LiAgent + 294 (in Lithium) [0x1db4d36]
45 __ZN16LiRenderInstance16buildHeliumGraphER7LiAgent + 524 (in Lithium) [0x1db2abc]
45 __ZN16LiRenderInstance7collectEv + 2129 (in Lithium) [0x1db24f1]
45 __ZN16LiRenderInstance9collect3DEP13LiSceneObjectR14LiCollectState + 1580 (in Lithium) [0x1db070c]
45 __ZN16LiRenderInstance12collectGroupEP7LiGroupR14LiCollectStateS3_ + 427 (in Lithium) [0x1db0a9b]
45 __ZN16LiRenderInstance9collect3DEP13LiSceneObjectR14LiCollectState + 1385 (in Lithium) [0x1db0649]
45 __ZN16LiRenderInstance12collectGeodeEP7LiGeodeR14LiCollectState + 913 (in Lithium) [0x1daf841]
45 __ZN17LiPolygonInstance8makeNodeERK9LiClipSet + 1713 (in Lithium) [0x1d89c61]
45 __ZN15OZLiFxGenerator9getHeliumER7LiAgent + 133 (in Ozone) [0x1374ee5]
45 __ZN18OZProPlugGenerator9getHeliumER7LiAgentfR14OZRenderParams + 1947 (in Ozone) [0x11880db]
45 __Z24OZProPlug_CallFrameSetupPvP11objc_object12FxRenderInfoP11FxImageInfoPaS5_ + 122 (in Ozone) [0x136e03a]
45 __Z17LockRecursiveLockPv + 34 (in Ozone) [0x13a9a92]
Thread id: cdcaf20
User stack:
Thread id: d3f7c80
User stack:
Thread id: c5c6208
User stack:
Thread id: cdcb2e8
User stack:
Thread id: c7d3a78
User stack:
45 _jpegdecompress_MPLoop + 79 (in QuickTimeComponents) [0x9249d4cb]
Thread id: f239b58
User stack:
Thread id: eb6b000
User stack:
Thread id: cdca3c8
User stack:
Thread id: c5c4b58
User stack:
45 __ZN12OZRenderUnit24processRenderInstructionEP19OZRenderInstruction + 167 (in Ozone) [0x108e4f7]
45 __ZN10GLRenderer36renderSingleDocumentObjectWithHeliumEP12OZRenderNodeR14OZRenderParams + 474 (in Ozone) [0x105737a]
45 __ZN10GLRenderer27findOrCreateRendererBuilderEP12OZRenderNodeR14OZRenderParamsb + 930 (in Ozone) [0x1051b62]
Thread id: f5b8410
User stack:
Thread id: cdcc208
User stack:
Thread id: cdcb6b0
User stack:
45 __ZN21OZRendererBuilderUnit24processRenderInstructionEP28OZRendererBuilderInstruction + 1571 (in Ozone) [0x13c34d3]
45 __ZN10GLRenderer12getFrameNodeEP12OZRenderNodeR14OZRenderParamsP10HGRendererPl + 2678 (in Ozone) [0x104ba06]
45 __ZN16LiRenderInstance12collectGroupEP7LiGroupR14LiCollectStateS3_ + 2549 (in Lithium) [0x1db12e5]
45 __ZN18OZProPlugGenerator9getHeliumER7LiAgentfR14OZRenderParams + 3164 (in Ozone) [0x118859c]
45 __Z20OZProPlug_CallRenderPvP11objc_objectPK16OZProcessControlP7FxImageS6_12FxRenderInfoRK14OZRenderParams + 737 (in Ozone) [0x136e561]
40 -[GeneratorDefaultBase renderOutput:withInfo:] + 154 (in Filters) [0x218d513c]
12 -[PerlinNoiseV2 canThrowRenderOutput:withInfo:] + 9883 (in Filters) [0x21873497]
12 _glVertex2f + 38 (in libGL.dylib) [0x96c4b4a6]
12 _glVertex2f_Exec + 72 (in GLEngine) [0x668d728]
2 _gleRunVertexSubmitImmediate + 977 (in GLEngine) [0x671e9b1]
2 _gleRunVertexSubmitImmediate + 6176 (in GLEngine) [0x671fe00]
1 _gleGetOffsetForCode + 0 (in GLEngine) [0x6718410]
1 _gleRunVertexSubmitImmediate + 6170 (in GLEngine) [0x671fdfa]
1 _gleRunVertexSubmitImmediate + 6164 (in GLEngine) [0x671fdf4]
1 _gleRunVertexSubmitImmediate + 1358 (in GLEngine) [0x671eb2e]
1 _gleRunVertexSubmitImmediate + 430 (in GLEngine) [0x671e78e]
1 _gleRunVertexSubmitImmediate + 958 (in GLEngine) [0x671e99e]
1 _gleRunVertexSubmitImmediate + 3941 (in GLEngine) [0x671f545]
1 _gleRunVertexSubmitImmediate + 3870 (in GLEngine) [0x671f4fe]
6 -[PerlinNoiseV2 canThrowRenderOutput:withInfo:] + 9143 (in Filters) [0x218731b3]
6 _glVertex2f + 38 (in libGL.dylib) [0x96c4b4a6]
6 _glVertex2f_Exec + 72 (in GLEngine) [0x668d728]
1 _gleRunVertexSubmitImmediate + 984 (in GLEngine) [0x671e9b8]
1 _gleRunVertexSubmitImmediate + 35 (in GLEngine) [0x671e603]
1 _gleRunVertexSubmitImmediate + 6182 (in GLEngine) [0x671fe06]
1 _gleRunVertexSubmitImmediate + 500 (in GLEngine) [0x671e7d4]
1 _gleLLVMSubmitFunc + 102 (in GLEngine) [0x671c436]
1 _gleCalculateDropEdge + 26 (in GLEngine) [0x671829a]
5 -[PerlinNoiseV2 canThrowRenderOutput:withInfo:] + 7711 (in Filters) [0x21872c1b]
5 _glVertex2f + 38 (in libGL.dylib) [0x96c4b4a6]
5 _glVertex2f_Exec + 72 (in GLEngine) [0x668d728]
1 _gleRunVertexSubmitImmediate + 3864 (in GLEngine) [0x671f4f8]
1 _gleCalculateDropEdge + 48 (in GLEngine) [0x67182b0]
1 __Z19calculateCellValuesiiifP11SCellValues + 2014 (in Filters) [0x21870c56]
1 __Z19calculateCellValuesiiifP11SCellValues + 86 (in Filters) [0x218704ce]
1 __Z19calculateCellValuesiiifP11SCellValues + 1742 (in Filters) [0x21870b46]
1 __Z19calculateCellValuesiiifP11SCellValues + 98 (in Filters) [0x218704da]
1 __Z19calculateCellValuesiiifP11SCellValues + 174 (in Filters) [0x21870526]
1 __Z19calculateCellValuesiiifP11SCellValues + 1962 (in Filters) [0x21870c22]
1 -[PerlinNoiseV2 canThrowRenderOutput:withInfo:] + 8403 (in Filters) [0x21872ecf]
1 _glVertex2f + 38 (in libGL.dylib) [0x96c4b4a6]
1 _glVertex2f_Exec + 72 (in GLEngine) [0x668d728]
1 _gleRunVertexSubmitImmediate + 6032 (in GLEngine) [0x671fd70]
1 __Z19calculateCellValuesiiifP11SCellValues + 2259 (in Filters) [0x21870d4b]
1 __Z19calculateCellValuesiiifP11SCellValues + 1957 (in Filters) [0x21870c1d]
1 _glVertex2f_Exec + 73 (in GLEngine) [0x668d729]
1 __Z19calculateCellValuesiiifP11SCellValues + 1847 (in Filters) [0x21870baf]
1 __Z19calculateCellValuesiiifP11SCellValues + 1979 (in Filters) [0x21870c33]
1 __Z19calculateCellValuesiiifP11SCellValues + 1528 (in Filters) [0x21870a70]
1 __Z19calculateCellValuesiiifP11SCellValues + 799 (in Filters) [0x21870797]
1 __Z19calculateCellValuesiiifP11SCellValues + 1764 (in Filters) [0x21870b5c]
1 _glMultiTexCoord4f + 13 (in libGL.dylib) [0x96c4fd9d]
1 __Z19calculateCellValuesiiifP11SCellValues + 1161 (in Filters) [0x21870901]
1 -[PerlinNoiseV2 canThrowRenderOutput:withInfo:] + 7115 (in Filters) [0x218729c7]
1 -[PerlinNoiseV2 canThrowRenderOutput:withInfo:] + 6911 (in Filters) [0x218728fb]
1 -[PerlinNoiseV2 canThrowRenderOutput:withInfo:] + 6311 (in Filters) [0x218726a3]
1 -[PerlinNoiseV2 canThrowRenderOutput:withInfo:] + 9731 (in Filters) [0x218733ff]
1 ??? [0x2193b032]
Kernel stack:
45 _PE_incoming_interrupt + 131 [0x44e416]
45 _lapic_interrupt + 121 [0x1b16c0]
45 _sync_iss_to_iks + 114 [0x1aa3ae]
Thread id: f5b8048
User stack:
44 _thread_start + 34 (in libSystem.B.dylib) [0x90dfd012]
44 __pthread_start + 321 (in libSystem.B.dylib) [0x90dfd155]
44 _PrivateMPEntryPoint + 56 (in CarbonCore) [0x97100fbb]
44 __ZN15TFolderSizeTask18FolderSizeTaskProcEPv + 104 (in DesktopServicesPriv) [0x96db1db4]
44 _MPWaitOnQueue + 208 (in CarbonCore) [0x97102a60]
44 _TSWaitOnConditionTimedRelative + 246 (in CarbonCore) [0x970e1c62]
44 _semaphore_timedwait_signal_trap + 10 (in libSystem.B.dylib) [0x90dcc2c6]
Process: ATSServer [157]
Path: /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/ATSServer
ADDRESS BINARY
00001000 /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/ATSServer
Thread id: 768da78
User stack:
46 ??? [0x4b46]
46 ??? [0xdd21f]
46 _CFRunLoopRun + 84 (in CoreFoundation) [0x95f5bb04]
1 _CFRunLoopRunSpecific + 3896 (in CoreFoundation) [0x95f5b6b8]
1 ___CFMachPortPerform + 117 (in CoreFoundation) [0x95f36ff5]
1 ??? [0xda8a9]
1 ??? [0xd7dde]
1 ??? [0xe4018]
1 ??? [0xa97c6]
1 ??? [0xa946e]
1 ??? [0xa8001]
1 ??? [0xa7df5]
1 ??? [0xa7bba]
1 ??? [0xafb9d]
1 ??? [0xab835]
1 ??? [0xa61cf]
1 _sqlite3_step + 29 (in libsqlite3.0.dylib) [0x96f7855d]
1 _sqlite3Step + 386 (in libsqlite3.0.dylib) [0x96f77ea2]
1 _sqlite3VdbeExec + 22966 (in libsqlite3.0.dylib) [0x96f71656]
1 _sqlite3VdbeHalt + 3198 (in libsqlite3.0.dylib) [0x96f2746e]
1 _fsync$UNIX2003 + 10 (in libSystem.B.dylib) [0x90e10d3e]
Kernel stack:
1 _unix_syscall + 572 [0x3e3a7f]
1 _fsync_nocancel + 102 [0x1e7f15]
1 _VNOP_FSYNC + 104 [0x1f51fe]
1 _GetLogicalBlockSize + 42477 [0x348441]
1 _GetLogicalBlockSize + 25373 [0x344171]
1 _cluster_push + 40 [0x1d278f]
1 _cluster_push_ext + 281 [0x1d2756]
1 _vnode_waitforwrites + 167 [0x1dd32e]
1 _msleep + 157 [0x3863e8]
1 _uiomove + 653 [0x386037]
1 _lck_mtx_sleep + 87 [0x130d90]
1 _thread_block + 33 [0x136f20]
1 _thread_block_reason + 135 [0x136e7c]
1 _thread_setrun + 3597 [0x136217]
1 _machine_idle + 271 [0x1ac3ec]
Thread id: 7c5b208
User stack:
46 _mach_msg_trap + 10 (in libSystem.B.dylib) [0x90dcc266]
Process: AirPort Base Station Agent [147]
Path: /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
ADDRESS BINARY
00001000 /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
000f9000 /Library/InputManagers/Cooliris/Cooliris.bundle/Contents/MacOS/Cooliris
0041c000 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
00424000 /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
004a8000 /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
00524000 /Library/Frameworks/DivX Toolkit.framework/Versions/A/DivX Toolkit
0052c000 /Library/QuickTime/Motion.component/Contents/MacOS/Motion
00578000 /Library/Frameworks/Motion.framework/Versions/A/Motion
00580000 /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
0065d000 /Library/QuickTime/macam.component/Contents/MacOS/macam
Thread id: 76cd8b8
User stack:
46 ??? [0x25ad]
46 ??? [0x2680]
46 _NSApplicationMain + 574 (in AppKit) [0x951d51d8]
46 -[NSApplication run] + 795 (in AppKit) [0x95207f9f]
46 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128 (in AppKit) [0x9520ef88]
46 __DPSNextEvent + 657 (in AppKit) [0x9520f6d5]
46 _BlockUntilNextEventMatchingListInMode + 106 (in HIToolbox) [0x93823f39]
46 _ReceiveNextEventCommon + 374 (in HIToolbox) [0x938240c5]
46 _RunCurrentEventLoopInMode + 283 (in HIToolbox) [0x938242ac]
46 _CFRunLoopRunInMode + 88 (in CoreFoundation) [0x95f5baa8]
Thread id: 861a7d8
User stack:
46 ___select + 10 (in libSystem.B.dylib) [0x90e1b6fa]
Process: AppleSpell [191]
Path: /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
ADDRESS BINARY
00001000 /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
000f9000 /usr/lib/liblangid.dylib
Thread id: c5c7c80
User stack:
46 ??? [0x1e86]
46 ??? [0x218d]
46 -[NSSpellServer run] + 198 (in Foundation) [0x913aa596]
Process: DashboardClient [218]
Path: /System/Library/CoreServices/Dock.app/Contents/Resources/DashboardClient.app/Contents/MacOS/DashboardClient
ADDRESS BINARY
00001000 /System/Library/CoreServices/Dock.app/Contents/Resources/DashboardClient.app/Contents/MacOS/DashboardClient
0002d000 /Library/InputManagers/Cooliris/Cooliris.bundle/Contents/MacOS/Cooliris
000b5000 /Library/Widgets/iCal.wdgt/Calendar.widgetplugin/Contents/MacOS/Calendar
000bf000 /Library/Widgets/Translation.wdgt/Translation.widgetplugin/Contents/MacOS/Translation
000d8000 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
000df000 /Library/Widgets/World Clock.wdgt/WorldClock.widgetplugin/Contents/MacOS/WorldClock
007d2000 /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaPluginCocoa.bundle/Contents/MacOS/JavaPluginCocoa
007d9000 /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
14e6f000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
15c45000 /Library/Widgets/Flight Tracker.wdgt/FlightTrackerComboBoxPlugin.plugin/Contents/MacOS/FlightTrackerComboBoxPlugin
16920000 /System/Library/PrivateFrameworks/Calculate.framework/Calculate
Thread id: c7d6ba0
User stack:
46 ??? [0x2b7a]
46 ??? [0xa545]
Thread id: cdccd60
User stack:
Thread id: cdcba78
User stack:
46 _thread_start + 34 (in libSystem.B.dylib) [0x90dfd012]
46 __pthread_start + 321 (in libSystem.B.dylib) [0x90dfd155]
46 __Z22CFURLCacheWorkerThreadPv + 388 (in CFNetwork) [0x9480818c]
Thread id: c7d58b8
User stack:
Thread id: 78b0790
User stack:
Process: DashboardClient [219]
ADDRESS BINARY
000bc000 /Users/Ty PPC/Library/Widgets/Mamp Control.wdgt/mampwidget.widgetplugin/Contents/MacOS/mampwidget
12eef000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
Thread id: cdcc5d0
User stack:
46 ??? [0x2b7a]
46 ??? [0xa545]
Thread id: c7d32e8
User stack:
Thread id: c7d4998
User stack:
Thread id: c5c4790
User stack:
Thread id: c5c5e40
User stack:
Process: DirectoryService [11]
Path: /usr/sbin/DirectoryService
ADDRESS BINARY
00001000 /usr/sbin/DirectoryService
00160000 /System/Library/PrivateFrameworks/DirectoryServiceCore.framework/Versions/A/DirectoryServiceCore
Thread id: 6e6a048
User stack:
46 start + 54 (in DirectoryService) [0x1631a]
46 _main + 2767 (in DirectoryService) [0x16e07]
Thread id: 6d8cc80
User stack:
46 __ZN9DSLThread11_RunWrapperEPv + 84 (in DirectoryServiceCore) [0x168166]
46 __ZN9DSCThread3RunEv + 39 (in DirectoryServiceCore) [0x167f5b]
46 __ZN20CPluginRunLoopThread10ThreadMainEv + 222 (in DirectoryService) [0x22fc4]
Thread id: 6d8aa78
User stack:
46 __ZN17CMigHandlerThread10ThreadMainEv + 303 (in DirectoryService) [0x231fd]
Kernel stack:
46 _dtrace_get_cpu_int_stack_top + 543 [0x198fa3]
46 _mach_msg_overwrite_trap + 3808 [0x1270ea]
46 _ipc_mqueue_receive + 750 [0x121292]
46 _thread_block + 33 [0x136f20]
46 _thread_continue + 1180 [0x136cb3]
Thread id: 6e71e40
User stack:
46 _kevent + 10 (in libSystem.B.dylib) [0x90dfc9c6]
Thread id: d3f4790
User stack:
46 ___syscall + 5 (in libSystem.B.dylib) [0x90e0e3a5]
Thread id: f239000
User stack:
46 __ZN17CMigHandlerThread10ThreadMainEv + 162 (in DirectoryService) [0x23170]
Process: Dock [160]
Path: /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
ADDRESS BINARY
00001000 /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
00400000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
Thread id: 7c5b998
User stack:
46 ??? [0x537a]
46 ??? [0x97e97]
46 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 213 (in Foundation) [0x913673d5]
Thread id: 814e208
User stack:
46 ??? [0x1340d]
Thread id: 8619c80
User stack:
Process: Finder [163]
Path: /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
ADDRESS BINARY
00001000 /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
004e5000 /System/Library/Frameworks/Collaboration.framework/Versions/A/Collaboration
004fe000 /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
00527000 /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
00596000 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
15b5a000 /System/Library/PrivateFrameworks/URLMount.framework/URLMount
1662d000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
Thread id: 814e5d0
User stack:
46 ??? [0x9376]
46 ??? [0xf3275]
46 ??? [0x233b9]
46 _RunApplicationEventLoop + 207 (in HIToolbox) [0x938812b3]
46 __AcquireNextEvent + 58 (in HIToolbox) [0x93882b56]
Thread id: 814cb58
User stack:
46 _PrivateMPEntryPoint + 56 (in CarbonCore) [0x97100fbb]
46 __ZN23TSystemNotificationTask26SystemNotificationTaskProcEPv + 123 (in DesktopServicesPriv) [0x96da4d0f]
Thread id: 814cf20
User stack:
46 __ZN25TFSEventsNotificationTask28FSEventsNotificationTaskProcEPv + 216 (in DesktopServicesPriv) [0x96da4e88]
Thread id: 814c3c8
User stack:
46 __ZN13TNodeSyncTask12SyncTaskProcEPv + 84 (in DesktopServicesPriv) [0x96dafe6a]
46 _MPWaitOnQueue + 208 (in CarbonCore) [0x97102a60]
46 _TSWaitOnConditionTimedRelative + 202 (in CarbonCore) [0x970e1c36]
46 _TSWaitOnCondition + 126 (in CarbonCore) [0x97102de3]
Thread id: 86172e8
User stack:
Kernel stack:
1 _kevent + 784 [0x37145b]
1 _kevent_scan + 389 [0x371104]
1 _thread_block_parameter + 32 [0x136efd]
Thread id: 8616b58
User stack:
Thread id: f5b3410
User stack:
45 __ZN15TFolderSizeTask18FolderSizeTaskProcEPv + 104 (in DesktopServicesPriv) [0x96db1db4]
Process: KernelEventAgent [35]
Path: /usr/sbin/KernelEventAgent
ADDRESS BINARY
00001000 /usr/sbin/KernelEventAgent
Thread id: 76ccd60
User stack:
Thread id: 777a5d0
User stack:
Process: Preview [698]
Path: /Applications/Preview.app/Contents/MacOS/Preview
ADDRESS BINARY
00001000 /Applications/Preview.app/Contents/MacOS/Preview
00201000 /Library/InputManagers/Cooliris/Cooliris.bundle/Contents/MacOS/Cooliris
0046a000 /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
129c2000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
15672000 /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
15825000 /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLDriver
181d4000 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
Thread id: d71d5d0
User stack:
46 start + 54 (in Preview) [0x21b2]
Thread id: d71f7d8
User stack:
Thread id: d71c2e8
User stack:
Thread id: d71bf20
User stack:
Thread id: d71bb58
User stack:
Thread id: d71b790
User stack:
Thread id: d71b3c8
User stack:
Thread id: d71b000
User stack:
Thread id: eb6fba0
User stack:
Thread id: eb6f7d8
User stack:
Thread id: eb6f410
User stack:
Process: QuickTime Player [12034]
Path: /Applications/QuickTime Player.app/Contents/MacOS/QuickTime Player
ADDRESS BINARY
00001000 /Applications/QuickTime Player.app/Contents/MacOS/QuickTime Player
0019e000 /Library/InputManagers/Cooliris/Cooliris.bundle/Contents/MacOS/Cooliris
003e6000 /usr/lib/libmx.A.dylib
00466000 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0046e000 /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
004f2000 /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
0056e000 /Library/Frameworks/DivX Toolkit.framework/Versions/A/DivX Toolkit
00576000 /Library/QuickTime/Motion.component/Contents/MacOS/Motion
005c2000 /Library/Frameworks/Motion.framework/Versions/A/Motion
005ca000 /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
0072a000 /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
00775000 /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense
007b5000 /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
007be000 /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
12c58000 /Library/QuickTime/macam.component/Contents/MacOS/macam
15981000 /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
15ba8000 /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
15e43000 /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
15eb7000 /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
16178000 /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
16300000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
166d2000 /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
16885000 /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLDriver
18b3c000 /Library/QuickTime/Blackmagic Codec.component/Contents/MacOS/Blackmagic Codec
18c48000 /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
18e4d000 /Library/QuickTime/AppleAVCIntraCodec.comp
zak peric
Re: Crashes when I import Generator content
on Dec 4, 2010 at 6:56:10 pm
Delete the preferences of motion.
Robert Phillips
on Dec 4, 2010 at 7:27:01 pm
Hi Zak
Thanks I just tried that and still got the same spinning beach ball.
Robert Phillips
FCP 7
Mac Pro OS 10.5.8
Gareth Randall
on Dec 4, 2010 at 10:25:30 pm
Hi Robert,
FWIW, trashing the preferences has NEVER solved any Motion problem I've ever had :)
Have you confirmed that it's a general problem, and not a project-specific one? In other words, if you create a new project, does the same thing happen when you try and import a generator? Individual projects can become corrupted for some reason, meaning that strange things start happening. You can often get around this by creating a new project and pasting in all the layers from the corrupted one.
If it *is* a general problem, then your only real option is to reinstall Motion. Although Apple's official line is that you have to reinstall the complete FCS suite, you don't need to waste that much time. Just go and get the freeware FCS Remover, use it to completely uninstall *just* Motion, and then use the shareware app Pacifist to inspect the FCS install disc, locate the Motion installer package, and reinstall Motion on its own.
Robert Phillips
on Dec 5, 2010 at 7:37:04 pm
Hi Gareth
It was indeed a general issue- not project specific. I did the reinstall as you described and it seems to be working fine now. Thanks for the help!
Robert Phillips
FCP 7
Mac Pro OS 10.5.8
Gareth Randall
on Dec 6, 2010 at 7:41:17 am
Glad to help :)
