Motion to FCP Template Text Issue
COW Forums : Apple Motion
patrick harper
on Nov 18, 2010 at 11:35:24 am
Not sure if this belongs in here or the FCP forum but here goes...
I'm attempting to build a basic template in Motion for use in FCP.
Everything works fine and I can open the template in FCP and then change the text within the template in the viewer.
BUT! When I press return to start a new line of text I get a small vertical line, a bit like an "i" but without the dot. How can I change the template's text content from one line to two without getting this line?
Many thanks,
Patrick
Mark Spencer
Re: Motion to FCP Template Text Issue
on Nov 18, 2010 at 1:47:46 pm
You need to change the text layout to a paragraph with the size you want in Motion.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
patrick harper
on Nov 18, 2010 at 3:08:16 pm
Thanks, Mark.
I just went back into Motion and added some blank lines under my original line of text.
As long as I don't press return when changing the template's text content in FCP and instead just click on one of the new blank lines it works a treat.
EDIT - Further investigation revealed it was an issue with the font (Gotham Bold) but the above fix was necessary anyway as client specifically requested that typeface.
