animate a jpeg on a b spline
COW Forums : Apple Motion
Jason King2
on Oct 22, 2010 at 4:20:44 am
Is it possible to take a b spline path you've created and attach a jpeg pict. to follow the path? I know you can do this with text, just wondering if it can be done with a picture.
zak peric
Re: animate a jpeg on a b spline
on Oct 22, 2010 at 12:35:02 pm
yes you can.
Select the image then apply behavior/basic motion then motion path. in the path properties change from bezier to B-Spline. then double klick on your path to add the points and create a direction to which you want your shape to go. EASY...
I hope this helps....
http://www.embryo.me.uk
Jason King2
on Oct 22, 2010 at 4:56:56 pm
Thanks, I figured there was a way. The manual is a little weak on explaining some things. I'm trying to dive a little deeper into the program and learn more.
