Simple edge blur, or feathering
COW Forums : Apple Motion
Matt Pennington
on Oct 1, 2010 at 3:46:26 pm
Wondering if anyone out there knows how to do a simple edge blur or feathering effect to an image that I've imported to a Motion project. In Final Cut this would be simple - under the motion tab select Crop and feather away.
I've done a little cropping to this image, but there's got to be an easy way to get this done, besides some several step process involving a mask, etc.
any thoughts would be greatly appreciated!
thanks,
Matt
Mark Spencer
Re: Simple edge blur, or feathering
on Oct 1, 2010 at 3:48:46 pm
Two steps: add a mask and feather the mask.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Stephen Smith
on Oct 1, 2010 at 3:52:28 pm
Matt,
Personally, I feel in the amount of time it takes to enable the Crop feature, move every crop slider you can add a rectangle mask and adjust the feather slider in the same amount of time. Plus, if you change your mind you can always add more points to your mask whereas you can't with the crop tool. Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Matt Pennington
on Oct 5, 2010 at 2:51:25 pm
Excellent, that does the trick. Think I was thinking too hard about this one, solution is quite simple.
Thanks fellas, always enjoy your tutorials,
Matt
Stephen Smith
on Oct 5, 2010 at 3:02:44 pm
Thanks Matt.
Stephen Smith
