variable spacing in template text objects
COW Forums : Apple Motion
David Krummenacher
on Sep 9, 2010 at 6:50:37 pm
I am trying to create a lower third template which has two different fonts on one line of text. I can create two text "boxes" or template fields, but is there a way to adjust the spacing between them so that I don't have an awkward gap between them?
Mark Spencer
Re: variable spacing in template text objects
on Sep 9, 2010 at 7:50:39 pm
Link the position of your second text box to a dummy text field so you can control its position FCP - here's a video that describes the process
http://pixelcorps.cachefly.net/mbks_078_540p_h264.mov
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
patrick harper
on Nov 22, 2010 at 2:58:04 pm
I have followed the tutorial but when it comes to changing the Link's Source Parameter to the Source Text's size I do not have that option.
The Compatible Parameters drop down menu only show Properties and Object but not Style so I cannot link it to the hidden text's size.
Any thoughts on where I might be going wrong?
Many thanks,
Patrick
Rebuilt from scratch and works fine. Don't think I did anything different so perhaps just a bug?
