Slowdown playback speed of timeline?
COW Forums : Apple Motion
Jeremy Peplow
on Sep 7, 2010 at 4:24:30 pm
Hello All,
I'm trying to use the "record on the fly" feature of motion to animates an object. For example, I have an object that I need to animate on a persons hand for a clip thats about 10 seconds in duration. I know I can arrow to each frame and add a keyframe but I would like to just hit record and then play and animate on the fly. The problem when I try this technique is the playback speed is way too fast. Is there a way to play my timeline much slower? I know I can slow the clip down but that just screws up all the keyframes when I set the clip back to 100%. Seems like an easy thing to do but I can't figure out how to do it anywhere.
Jeremy
Sacha Thomas
Re: Slowdown playback speed of timeline?
on Sep 7, 2010 at 7:54:55 pm
It sounds like the motion tracking behaviors would be of use. It would at least allow you to focus on the animation rather than both animation and position. I am not sure what you are trying to do but that might work for you. Good luck.
