1440 x 1080?
COW Forums : Apple Motion
Larry Watts
1440 x 1080?
on Aug 30, 2010 at 1:18:57 am
We bought a motion template that was 1920 x 1080 for a theatre ad we are doing.
Somehow during the editing of the template I noticed it had changed to 1440 x 1080.
I haven't a clue how it got that way!
I need to convert it back before submitting this week an we've done quite a bit of work on it.
Anyone have some solutions?
Larry
Stephen Smith
Re: 1440 x 1080?
on Aug 30, 2010 at 2:37:30 pm
1440 x 1080 is the same size as 1920 x 1080 (mostly). What I'm saying is, it will end up 1920 x 1080 when all is said and done. If you really need to change it go up to Edit, Project Properties, and choose something like XDCAM EX 1080i60 for the preset. Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Larry Watts
Re: 1440 x 1080?
on Aug 30, 2010 at 6:23:40 pm
thanks!
By same do you mean 1920 = square pixels and 1440 are rectangular?
How exactly does it all work out in the end? The project looks like it would have to stretch and distort it?
Larry
Stephen Smith
Re: 1440 x 1080?
on Aug 30, 2010 at 6:45:34 pm
Uncompressed HD video transferred via an HD-SDI signal has pixel dimensions of either 1280 x 720 or 1920 x 1080. However, HD video recorded on tape is often horizontally compressed to reduce the data rate. DVCPRO HD, HDV, and HDCAM are three examples of formats whose native horizontal dimensions are squeezed. For example, 1080i60 DVCPRO HD is 1280 x 1080. 1080i50 DVCPRO HD is 1440 x 1080. We shoot some stuff on the Panasonic 200 and it comes in at 1080i60 DVCPRO HD is 1280 x 1080. FCP know how to interrupt it. What I'm saying is 1440 x 1080 is often marketed as 1920 x 1080.
If you want the best settings because of the discrepancy in dimensions even within a single format, it’s usually best to create HD graphics at either 1920 x 1080 or 1280 x 720, depending on your final output format.
Stephen Smith
