How to Move Text 1 direction with Audio Behavior?
COW Forums : Apple Motion
John Jones
on Aug 29, 2010 at 7:55:29 pm
Hi, I'm trying to use the audio behavior to create an effect for a title screen.
When you heat the giant footsteps, the text pulses fowards. It does this in response to the audio track.
The problem I have is that if you apply the audio behavior to the position the text just jumps fowards and backwards and ends up where it was. I want the text to move foward in the z direction towards the camera and end up closer than when you started.
I figured that you have to apply some motion behaviors to the text, and animate them using the audio behavior. So I created a motion path and used the audio behavior to animate the "custom speed" of the motion path but the speed of movement still seemed constant even if I cranked up the strengh to the max.
Any ideas how to do this?
thanks.
Mark Spencer
Re: How to Move Text 1 direction with Audio Behavior?
on Aug 30, 2010 at 3:21:00 pm
That's a really interesting question - really not sure how to make that happen, but would be cool if you could. Let's see if anyone else weighs in.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
